Backup of the current config
kksan
Post by kksan »
Hi all,
I was wandering a way to backup the configuration of Alcatel switches without using an omnivista.
Do you know a way to do it?
Thank you all
Re: Backup of the current config
you has to use a tool that can copy (login automaticly, for regurlary backups with a sceduler) the boot-files from the switch to your server. The switch can use ftp, sftp, scp.
aurik
Post by aurik »
I'm also interested in such software, did you find something relevent ?
omnivista 2500 can do it. For the first 10 switches the license is for free.
aurik
Post by aurik »
Thank's, but, like you, I try to find something without omnivista... ;-)
rekeds
Post by rekeds »
what is the issue? lots of open source, when i started, used expect script and diff
Return to “OmniSwitch 6900”
