RADIUS
nsotis28
RADIUS
Post by nsotis28 »
Dear all,
I need your help to configure Radius auth on the switch.
My concern is related to server part , since sw configuration is straight forward.
In general i know how to configure Radius ( done before with Dell , Cisco) but i think that my mistake here is on vendor specific attributes ( see attached file )
Is there a guide for this ?
Re: RADIUS
I assume you would allow management access to the switches (f.e. aaa authentication ssh RADIUS-1) - not for 802.1x.
For this you need the following vendor specific attributes (rfc conform for vendor 800):
attribut number 9 with string "all"
and
attributes 39-46 with hex "FFFFFFFF"
FFFFFFFF means all rights for read-write (like admin user).
nsotis28
Re: RADIUS
Post by nsotis28 »
It worked , thanks for your assistance
Return to “OmniSwitch 6450”
