AOS is rebooting again and again. I think , its AOS (7.3.4.204.R02) is corrupted.
Can somebody explain its upgrading AOS steps. and provide me its rescue image for disaster recovery
os6900-x40 rebooting again and again
devnull
Re: os6900-x40 rebooting again and again
Open a SR,
They will provide you with the TRescue.img
If the device is rebooting: What do you see on the console?
ramandeep
================Logs======================
U-Boot 2008.10 7.2.1.R02.266 (Jan 17 2012 - 01:46:47)
CPU0: 8572, Version: 2.2, (0x80e00022)
Core: E500, Version: 3.0, (0x80210030)
Clock Configuration:
CPU0:1200 MHz, CPU1:1200 MHz, CCB:400 MHz,
DDR:333.330 MHz (666.660 MT/s data rate) (Asynchronous),
LBC:50 MHz
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
I2C1: 200 MHz, 200000 KHz
I2C2: 200 MHz, 200000 KHz
Board: OS6900-X40
I2C: Bus speed: 97656
ready
DRAM: Initializing....
No module at address addr 56
DDR: 2 GB
OS6900-X40 initializing devices
Expansion board 1 absent
Expansion board 2 present
Fan tray Evacuating
PS1: Present: YM-2451CJR: Evacuating
PS2: Present: YM-2451CJR: Evacuating
EMP out of reset
Trident out of reset
FLASH: Bank 0, 30 MB, base address 0xF0000000
Bank 1, 2 MB, base address 0xFFE00000
Total size: 32 MB
L2: 1024 KB enabled
CPUs ready: CPU0 CPU1
Using default environment
eTSEC1 is in sgmii mode.
eTSEC2 is in sgmii mode.
eTSEC3 is in sgmii mode.
eTSEC4 is in sgmii mode.
PCIE3: Root Complex x2 lanes at (base address ff708000)
PCIE3 on bus 00 - 00
PCIE2: Root Complex x2 lanes at (base address ff709000)
PCIE2 on bus 01 - 01
PCIE1: Root Complex x4 lanes at (base address ff70a000)
Scanning PCI bus 03
03 00 14e4 b845 0200 00
PCIE1 on bus 02 - 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
Net: eTSEC1: PHY is TBI <-> SerDes (ffff)
eTSEC2: PHY is TBI <-> SerDes (ffff)
eTSEC3: PHY is TBI <-> SerDes (ffff)
eTSEC4: PHY is Marvell 88E1111 (1410cc2)
eTSEC1, eTSEC2, eTSEC3, eTSEC4
IDE: Bus 0: OK
Device 0: Model: CF 2GB Firm: 20100924 Ser#: 2013C 0000106139
Type: Removable Hard Disk
Capacity: 2000.7 MB = 1.9 GB (4097520 x 512)
USB: scanning bus for devices... 1 USB Devices found
nvram baudrate is 9600
nvram netmask is 0.0.0.0
nvram ipaddr is 0.0.0.0
nvram gatewayip is 0.0.0.0
nvram current is certified
nvram next is certified
cf type is EXT2
Hit any key to stop autoboot: 2 1 0
ü
LBC:50 MHz
Board: OS6900-X40
ready
DDR: 2 GB
Fan tray Evacuating
EMP out of reset
Total size: 32 MB
L2: 1024 KB enabled
Scanning PCI bus 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
IDE: Bus 0: OK
USB: scanning bus for devices... 2 USB Devices found
cf type is EXT2
126642216 bytes read
WARNING: adjusting available memory to 30000000
## Booting kernel from FIT Image at 11000000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: Tor ppc8572 kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x110000d0
Data Size: 3984516 Bytes = 3.8 MB
Architecture: PowerPC
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: e63e7e2f
Hash algo: sha1
Hash value: c4c44cd05fa9692b5085d6a1fb3944a7a2616fa0
Verifying Hash Integrity ... crc32+ sha1+ OK
## Loading init Ramdisk from FIT Image at 11000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Tor ramdisk
Type: RAMDisk Image
Data Start: 0x117e7354
Data Size: 118354300 Bytes = 112.9 MB
Hash algo: crc32
Hash value: 631565c8
Hash algo: sha1
Hash value: 8587c0b87a20bba4c5d0b4eaa2e2c9566a2eac4e
## Flattened Device Tree from FIT Image at 11000000
Trying 'fdt@1' FDT blob subimage
Description: Tor Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x117dd9b0
Data Size: 12998 Bytes = 12.7 kB
Hash algo: crc32
Hash value: eaaa2eaa
Hash algo: sha1
Hash value: 83f387fcf0fee16de11d248654f3cafffdb79dd8
Booting using the fdt blob at 0x117dd9b0
Uncompressing Kernel Image ... OK
Loading Ramdisk to 28f20000, end 2ffff17c ... OK
Loading Device Tree to 0fff9000, end 0ffff2c5 ... OK
setup_arch: bootmem
arch: exit
[ 3.408043] fsl_pm.ko: __pme_mem at c4000000:
Starting 6900 Boot Process
FS is EXT2
Preparing Flash...
(none) login:
Sat Jul 20 12:35:14 : ChassisSupervisor Power Mgr info message:
+++ PS 2 is up
a
Sat Jul 20 12:35:14 : ChassisSupervisor prbDB info message:
+++ PS 1,chassis_id 1 inserted
+++ PS 2,chassis_id 1 inserted
Alcatel-Lucent OS6900-X40 7.3.2.344.R01 GA, June 12, 2013.
Copyright(c), 1994-2013 Alcatel-Lucent. All Rights reserved.
Sat Jul 20 12:35:18 : ChassisSupervisor Power Mgr alert message:
+++ PS 1 reported down, v 0.0 i 0.0 p 0.0
Sat Jul 20 12:35:19 : ChassisSupervisor Power Mgr alert message:
+++ Marking PS 1 down ( 0.0/ 0.0/ 0.0)
Sat Jul 20 12:35:21 : ipv4 itf info message:
+++ Interface EMP 192.168.1.101/255.255.255.0
Sat Jul 20 12:35:22 : ipsec key info message:
+++ IPsec master security key not set
Sat Jul 20 12:35:29 : ChassisSupervisor MipMgr info message:
+++ Trap Sent from CCM: Warm Start Trap
chassis mode is
0
Sat Jul 20 12:35:34 : bcmd sdk info message:
+++ LCPLL 0 not locked on unit 0 status = 0x00000000
+++ LCPLL 1 not locked on unit 0 status = 0x00000000
+++ LCPLL 2 not locked on unit 0 status = 0x00000000
+++ LCPLL 3 not locked on unit 0 status = 0x00000000
Sat Jul 20 12:35:38 : bcmd esm error message:
+++ phy_nlp_init:ERROR: _nlp_init
Sat Jul 20 12:35:39 : bcmd esm error message:
Sat Jul 20 12:35:39 : ChassisSupervisor sfpPollerThread error message:
+++ expansion slot 2 (ni 3) pll not locked after 5 tries -- disabling
Sat Jul 20 12:35:40 : bcmd esm error message:
Sat Jul 20 12:35:41 : bcmd esm error message:
Sat Jul 20 12:35:42 : bcmd esm error message:
Sat Jul 20 12:35:43 : bcmd esm error message:
Sat Jul 20 12:35:43 : bcmd sdk info message:
+++ WC40 : TXPLL did not lock: u=0 p=13
Sat Jul 20 12:35:44 : bcmd esm error message:
Sat Jul 20 12:35:45 : bcmd esm error message:
Sat Jul 20 12:35:46 : bcmd esm error message:
Sat Jul 20 12:35:46 : bcmd nlpPhy error message:
+++ invalid speed mode
Sat Jul 20 12:35:47 : bcmd esm error message:
+++ phy_nlp_broadcast:ERROR: _nlp_set_speed firstPort:1 lastPort:20
Sat Jul 20 12:35:47 : bcmd nlpPhy error message:
+++ invalid fw mode
+++ phy_nlp_broadcast:ERROR: _nlp_firmware_download firstPort:1 lastPort:20
+++ firmware loaded incorrectly
+++ phy_nlp_init:ERR:2: firmware download failed port:1
+++ phy_nlp_init:ERR:2: firmware download failed port:2
+++ phy_nlp_init:ERR:2: firmware download failed port:3
+++ phy_nlp_init:ERR:2: firmware download failed port:4
+++ phy_nlp_init:ERR:2: firmware download failed port:5
+++ phy_nlp_init:ERR:2: firmware download failed port:6
+++ phy_nlp_init:ERR:2: firmware download failed port:7
+++ phy_nlp_init:ERR:2: firmware download failed port:8
+++ phy_nlp_init:ERR:2: firmware download failed port:9
+++ phy_nlp_init:ERR:2: firmware download failed port:10
+++ phy_nlp_init:ERR:2: firmware download failed port:11
+++ phy_nlp_init:ERR:2: firmware download failed port:12
+++ phy_nlp_init:ERR:2: firmware download failed port:13
+++ phy_nlp_init:ERR:2: firmware download failed port:14
+++ phy_nlp_init:ERR:2: firmware download failed port:15
+++ phy_nlp_init:ERR:2: firmware download failed port:16
+++ phy_nlp_init:ERR:2: firmware download failed port:17
+++ phy_nlp_init:ERR:2: firmware download failed port:18
+++ phy_nlp_init:ERR:2: firmware download failed port:19
+++ phy_nlp_init:ERR:2: firmware download failed port:20
Sat Jul 20 12:35:48 : bcmd esm error message:
Sat Jul 20 12:35:49 : bcmd esm error message:
Sat Jul 20 12:35:50 : bcmd esm error message:
Sat Jul 20 12:35:50 : bcmd sdk info message:
+++ WC40 : TXPLL did not lock: u=0 p=29
Sat Jul 20 12:35:51 : bcmd esm error message:
Sat Jul 20 12:35:52 : bcmd esm error message:
Sat Jul 20 12:35:53 : bcmd esm error message:
Sat Jul 20 12:35:54 : bcmd esm error message:
Sat Jul 20 12:35:54 : bcmd nlpPhy error message:
Sat Jul 20 12:35:55 : bcmd esm error message:
+++ phy_nlp_broadcast:ERROR: _nlp_set_speed firstPort:21 lastPort:40
Sat Jul 20 12:35:55 : bcmd nlpPhy error message:
+++ invalid fw mode
+++ phy_nlp_broadcast:ERROR: _nlp_firmware_download firstPort:21 lastPort:40
+++ phy_nlp_init:ERR:2: firmware download failed port:21
+++ phy_nlp_init:ERR:2: firmware download failed port:22
+++ phy_nlp_init:ERR:2: firmware download failed port:23
+++ phy_nlp_init:ERR:2: firmware download failed port:24
+++ phy_nlp_init:ERR:2: firmware download failed port:25
+++ phy_nlp_init:ERR:2: firmware download failed port:26
+++ phy_nlp_init:ERR:2: firmware download failed port:27
+++ phy_nlp_init:ERR:2: firmware download failed port:28
+++ phy_nlp_init:ERR:2: firmware download failed port:29
+++ phy_nlp_init:ERR:2: firmware download failed port:30
+++ phy_nlp_init:ERR:2: firmware download failed port:31
+++ phy_nlp_init:ERR:2: firmware download failed port:32
+++ phy_nlp_init:ERR:2: firmware download failed port:33
+++ phy_nlp_init:ERR:2: firmware download failed port:34
+++ phy_nlp_init:ERR:2: firmware download failed port:35
+++ phy_nlp_init:ERR:2: firmware download failed port:36
+++ phy_nlp_init:ERR:2: firmware download failed port:37
+++ phy_nlp_init:ERR:2: firmware download failed port:38
+++ phy_nlp_init:ERR:2: firmware download failed port:39
+++ phy_nlp_init:ERR:2: firmware download failed port:40
Sat Jul 20 12:35:55 : bcmd sdk info message:
+++ WC40 : TXPLL did not lock: u=0 p=45
+++ WC40 : TXPLL did not lock: u=0 p=49
+++ determineDevice:ERR: Port [53] deviceID:0xffff unknown!
+++ nlp_driver_init: iface == NULL
+++ invalid device or bad address
Sat Jul 20 12:35:58 : bcmd sdk info message:
+++ WC40 : uC init fails: u=0 p=53
+++ Unit 0 Port xe52: Failed to initialize PHY: Operation timed out
+++ MAC init failed on port xe53
+++ Error unit 0: Failed port probe: Feature not initialized
+++ bcm_init: port returned -17
Sat Jul 20 12:35:58 : bcmd init alarm message:
+++ bcm init failed 0 -17
+++ unit init failed 0 -84
+++ Thread 0 failed with return status -84
+++ module init fail 300 (-431)
Sat Jul 20 12:36:01 : ChassisSupervisor appMgr alert message:
+++ Task /bin/bcmd -p vrf () terminated without restart strategy - board restarting
+++ Failed App /bin/bcmd -p
Sat Jul 20 12:36:01 : ChassisSupervisor bootMgr info message:
+++ Reboot postponed pending PMD completion
plSharedMemorySetExpBoardProfile DEF_PROFILE
Sat Jul 20 12:36:01 : ChassisSupervisor niMgr info message:
+++ Expansion slot 2 (ni 3) extracted.
Sat Jul 20 12:36:01 : DACMM main warning message:
+++ [dacmm_debug] dacmmExpDownEventHandler():1255: Send to NI failed, errno[9]
logger: unknown priority name: terminated
Sat Jul 20 12:36:04 : ChassisSupervisor sfpPollerThread info message:
+++ power supply 1 down
Sat Jul 20 12:36:11 : ChassisSupervisor sfpPollerThread error message:
Sat Jul 20 12:36:11 : ChassisSupervisor niMgr info message:
Sat Jul 20 12:36:14 : PMD main alert message:
+++ PMD generated at /flash/pmd/pmd-07.20.2019-12.36.01
Disabling ports
All ports disabled
Sat Jul 20 12:36:15 2019 :: Local Flash Sync complete - fail watchdog is 0
Sat Jul 20 12:36:15 2019 :: Unmounting flash
Sat Jul 20 12:36:15 2019 :: Shutting down I2C bus
--- Sat Jul 20 12:36:16 2019 :: reboot shutdown complete - rebooting ---
[ 119.907736] Restarting system.
[ 119.944264] OS6900 putting phys into reset
[ 127.993238] OS6900 shutting ports down
[ 130.538046] OS6900 shutting expansion boards down
[ 131.594309] OS6900 rebooting
þ
LBC:50 MHz
Board: OS6900-X40
ready
DDR: 2 GB
Fan tray Evacuating
EMP out of reset
Total size: 32 MB
L2: 1024 KB enabled
Scanning PCI bus 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
IDE: Bus 0: OK
cf type is EXT2
Type: Kernel Image
OS: Linux
Hash algo: crc32
Hash algo: sha1
Type: RAMDisk Image
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
setup_arch: bootmem
arch: exit
[ 3.400817] fsl_pm.ko: __pme_mem at c4000000:
FS is EXT2
Preparing Flash...
(none) login:
Sat Jul 20 12:38:39 : ChassisSupervisor Power Mgr info message:
+++ PS 2 is up
Sat Jul 20 12:38:40 : ChassisSupervisor prbDB info message:
Sat Jul 20 12:38:44 : ChassisSupervisor Power Mgr alert message:
Sat Jul 20 12:38:45 : ChassisSupervisor Power Mgr alert message:
Sat Jul 20 12:38:46 : ipv4 itf info message:
Sat Jul 20 12:38:47 : ipsec key info message:
Sat Jul 20 12:38:54 : ChassisSupervisor MipMgr info message:
chassis mode is
0
Sat Jul 20 12:38:59 : bcmd sdk info message:
Sat Jul 20 12:39:04 : bcmd esm error message:
Sat Jul 20 12:39:05 : bcmd esm error message:
Sat Jul 20 12:39:05 : ChassisSupervisor sfpPollerThread error message:
Sat Jul 20 12:39:06 : bcmd esm error message:
Sat Jul 20 12:39:07 : bcmd esm error message:
Sat Jul 20 12:39:08 : bcmd esm error message:
Sat Jul 20 12:39:09 : bcmd sdk info message:
+++ WC40 : TXPLL did not lock: u=0 p=10
Sat Jul 20 12:39:09 : bcmd esm error message:
Sat Jul 20 12:39:10 : bcmd esm error message:
Sat Jul 20 12:39:12 : bcmd sdk info message:
+++ WC40 : uC init fails: u=0 p=13
+++ Unit 0 Port xe12: Failed to initialize PHY: Operation timed out
+++ MAC init failed on port xe13
Sat Jul 20 12:39:12 : bcmd init alarm message:
Sat Jul 20 12:39:15 : ChassisSupervisor appMgr alert message:
Sat Jul 20 12:39:15 : ChassisSupervisor bootMgr info message:
Sat Jul 20 12:39:18 : ChassisSupervisor niMgr info message:
Sat Jul 20 12:39:18 : DACMM main warning message:
Sat Jul 20 12:39:18 : ChassisSupervisor sfpPollerThread info message:
Sat Jul 20 12:39:28 : ChassisSupervisor sfpPollerThread error message:
Sat Jul 20 12:39:28 : ChassisSupervisor niMgr info message:
Sat Jul 20 12:39:28 : PMD main alert message:
+++ PMD generated at /flash/pmd/pmd-07.20.2019-12.39.16
Disabling ports
All ports disabled
Sat Jul 20 12:39:28 : ChassisSupervisor bootMgr alert message:
+++ _bootMgrRebootCMM: rebooting system
Sat Jul 20 12:39:29 2019 :: Local Flash Sync complete - fail watchdog is 0
Sat Jul 20 12:39:29 2019 :: Unmounting flash
Sat Jul 20 12:39:29 2019 :: Shutting down I2C bus
--- Sat Jul 20 12:39:30 2019 :: reboot shutdown complete - rebooting ---
[ 107.494334] Restarting system.
[ 107.530879] OS6900 putting phys into reset
ü
LBC:50 MHz
Board: OS6900-X40
ready
DDR: 2 GB
Expansion board 2 absent
Fan tray Evacuating
EMP out of reset
Total size: 32 MB
L2: 1024 KB enabled
Scanning PCI bus 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
IDE: Bus 0: OK
cf type is EXT2
Type: Kernel Image
OS: Linux
Hash algo: crc32
Hash algo: sha1
Type: RAMDisk Image
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
setup_arch: bootmem
arch: exit
[ 3.405089] fsl_pm.ko: __pme_mem at c4000000:
FS is EXT2
Preparing Flash...
(none) login:
Sat Jul 20 12:42:17 : ChassisSupervisor Power Mgr info message:
+++ PS 2 is up
Sat Jul 20 12:42:17 : ChassisSupervisor prbDB info message:
Sat Jul 20 12:42:21 : ChassisSupervisor Power Mgr alert message:
Sat Jul 20 12:42:22 : ChassisSupervisor Power Mgr alert message:
Sat Jul 20 12:42:24 : ipv4 itf info message:
Sat Jul 20 12:42:24 : ipsec key info message:
Sat Jul 20 12:42:32 : ChassisSupervisor MipMgr info message:
chassis mode is
0
Sat Jul 20 12:42:37 : bcmd sdk info message:
Sat Jul 20 12:42:42 : bcmd esm error message:
Sat Jul 20 12:42:43 : bcmd esm error message:
Sat Jul 20 12:42:44 : bcmd esm error message:
Sat Jul 20 12:42:45 : bcmd esm error message:
Sat Jul 20 12:42:46 : bcmd esm error message:
Sat Jul 20 12:42:47 : bcmd esm error message:
Sat Jul 20 12:42:49 : bcmd sdk info message:
Sat Jul 20 12:42:50 : bcmd sdk info message:
Sat Jul 20 12:42:50 : bcmd init alarm message:
Sat Jul 20 12:42:53 : ChassisSupervisor appMgr alert message:
Sat Jul 20 12:42:53 : ChassisSupervisor bootMgr info message:
Sat Jul 20 12:42:56 : ChassisSupervisor sfpPollerThread info message:
Disabling ports
Sat Jul 20 12:43:05 : PMD main alert message:
+++ PMD generated at /flash/pmd/pmd-07.20.2019-12.42.53
All ports disabled
Sat Jul 20 12:43:05 : ChassisSupervisor bootMgr alert message:
Sat Jul 20 12:43:06 2019 :: Local Flash Sync complete - fail watchdog is 0
Sat Jul 20 12:43:06 2019 :: Unmounting flash
Sat Jul 20 12:43:07 2019 :: Shutting down I2C bus
--- Sat Jul 20 12:43:07 2019 :: reboot shutdown complete - rebooting ---
[ 107.746342] Restarting system.
[ 107.782887] OS6900 putting phys into reset
[ 115.831864] OS6900 shutting ports down
[ 118.376672] OS6900 shutting expansion boards down
[ 119.432935] OS6900 rebooting
ÿ
=======Again same procedure start================
LBC:50 MHz
Board: OS6900-X40
ready
DDR: 2 GB
Fan tray Evacuating
EMP out of reset
Total size: 32 MB
L2: 1024 KB enabled
Scanning PCI bus 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
IDE: Bus 0: OK
cf type is EXT2
ü
LBC:50 MHz
Board: OS6900-X40
ready
DDR: 2 GB
Fan tray Evacuating
EMP out of reset
Total size: 32 MB
L2: 1024 KB enabled
Scanning PCI bus 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
IDE: Bus 0: OK
cf type is EXT2
Type: Kernel Image
OS: Linux
Hash algo: crc32
Hash algo: sha1
Type: RAMDisk Image
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
setup_arch: bootmem
arch: exit
FS is EXT2
Preparing Flash...
(none) login:
+++ PS 2 is up
a
chassis mode is
0
+++ invalid fw mode
+++ invalid fw mode
Disabling ports
All ports disabled
þ
LBC:50 MHz
Board: OS6900-X40
ready
DDR: 2 GB
Fan tray Evacuating
EMP out of reset
Total size: 32 MB
L2: 1024 KB enabled
Scanning PCI bus 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
IDE: Bus 0: OK
cf type is EXT2
Type: Kernel Image
OS: Linux
Hash algo: crc32
Hash algo: sha1
Type: RAMDisk Image
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
setup_arch: bootmem
arch: exit
FS is EXT2
Preparing Flash...
(none) login:
+++ PS 2 is up
chassis mode is
0
Disabling ports
All ports disabled
ü
LBC:50 MHz
Board: OS6900-X40
ready
DDR: 2 GB
Fan tray Evacuating
EMP out of reset
Total size: 32 MB
L2: 1024 KB enabled
Scanning PCI bus 03
Bus speed: 97656
In: serial
Out: serial
Err: serial
IDE: Bus 0: OK
cf type is EXT2
Type: Kernel Image
OS: Linux
Hash algo: crc32
Hash algo: sha1
Type: RAMDisk Image
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
setup_arch: bootmem
arch: exit
FS is EXT2
Preparing Flash...
(none) login:
+++ PS 2 is up
chassis mode is
0
Disabling ports
All ports disabled
ÿ
devnull
Looks strange.
Do you have an extension Card in the X40 ? e.g. a qni-U3 or an xni-u12?
Looks like there is some problem with a expansion card.
For me this smells like SR/RMA and nothing that can be fixed with a Rescue image.Sat Jul 20 12:35:39 : ChassisSupervisor sfpPollerThread error message:
ramandeep
Yes there are two cards installed.
OS-XNI-U12 and OS-HNI-U6
I tried to upgrade the AOS through USB method after removing expansion cards but not successful.
