turning off disconnect tone?
d-mgr
Post by d-mgr »
When one party hangs up on the other party you hear a disconnect tone, otherwise known as "disconnect tone", "calling party control" and maybe others. Does anyone know in OXO is there a label associated with this tone and can it be disabled?
Thanks.
morten_DUP
Re: turning off disconnect tone?
Post by morten_DUP »
Does any one find anything about this?
tuxalize
Post by tuxalize »
Well,
under system miscellaneous, feature design part 4 you will se Release timeout for sets with display and Release timeout for sets without display. These timers are the duration of "disconnection tone" is sent to the extension. You can reduce them.
Tux
morten_DUP
tuxalize wrote: under system miscellaneous, feature design part 4
Where is this section release 8 documentation? did not find it..
Friday
Post by Friday »
You will not find it where you are looking.....
We are talking OXO in this forum, not OXE..... :D
d-mgr
Post by d-mgr »
I forget why I posted the question but anyway it is not resolved.
torrentula
Post by torrentula »
I do believe Tux answered your question as long as your question relates to OXO.
morten_DUP
torrentula wrote:I do believe Tux answered your question as long as your question relates to OXO.
:? My mistake - this regards the OXE, any one know if it is possible to make the timer shorter, ore simply to remove the tone?
torrentula
Not that I'm aware of, if someone knows then please share. It annoys the hell out of me :evil:
morten_DUP
Me 2 this is really enjoying
Return to “Configuration”
