New CPU8 - LAN / Serial Connection
junoooni
Post by junoooni »
I have a new ACT28 with 2 x CPU-8's and 2 x IO2N boards and each CPU8 is connected to 1 x IO2N board with a weird board in front... my question is, how do i get access to CPU8 to configure IP and connect to customer network? i have installed CPU7 once but it came with a CBRMA board but this time i didnt got it.... is there any new connectivity?
alexeik
Re: New CPU8 - LAN / Serial Connection
Post by alexeik »
nope you need the cables on the backside and the cbrma connectingbox
junoooni
Post by junoooni »
I have got a BRMA box and a cable to incterconnect both CPU's (3BA28041AA), another cable (3BA28040) one end of it is marked with COM,ETH,VM,FD i have fixed this end on top of interconnection cable on main CPU and other part is connected to BRMA...then i have (3BA58074) which I have connected on top of backup CPU and then i have 2 x 33BA28208, where do i connect these?
i have powered on my system but still cannot take serial connection to it, any help will be appreciated
junoooni
Post by junoooni »
I am unable to get Com connection... neither i can see any light on CPU8...only IO2N boards have CPU lights blinking
alexeik
Post by alexeik »
do you have the systemdoku? look for oxe12.1_im_CrystalHw_8AL91028USAG_1_en.pdf on page 199 all is described
btw i have no idea what the cable 3BA28208 is...
edit found the cable in my own link... sry
junoooni
Post by junoooni »
hi alexeik
i connected using the document you referred but there isnt any activity on any of COM ports on BRMA
alexeik
Post by alexeik »
hmm
do you use a "nullmodem cable" for the connection from the brma to the PC?
junoooni
Post by junoooni »
Yes.. i m using a null modem cable
alexeik
Post by alexeik »
then i have no clue... should work
junoooni
Post by junoooni »
Finally it turned out that there was a lot of CPU-8 which BIOS wasnt compatible with Windows 10... ended up using an XP PC and everything worked fine
Return to “Boards”
