CCD objects not displayed on CCSupervision
beirut
Post by beirut »
I am having this issue when creating any CCD object, piliot/queue etc... It does not show on the CCSupervision.
OXE Rel,12.2. When I go under CCsupervision Configuration/pilot it is disabled.
I have already a Genesys express configured with OXE, and not sure if something was managed to disable this feature.
Re: CCD objects not displayed on CCSupervision
Was this working before? Can you post a screenshot?
beirut
Post by beirut »
it was resolved after a reboot.
Return to “Application”
