Could any one tell me how can i do factory reset omniswith 6860E?
Factory reset
Re: Factory reset
delete all the files and directories within the flash - beside certified/Uos.img (only this file is needed).
f.e. you are in the flash-directory (/flash) than you can use the following commands:
rm *
rm -r network
rm -r pmd
rm -r swlog_archive
rm -r system
rm -r switch
rm certified/vc*
rm working /vc*
than do a reload with "reload from working no rollback-timeout
and you switch is similar to factory.
rm *
rm -r network
rm -r pmd
rm -r swlog_archive
rm -r system
rm -r switch
rm certified/vc*
rm working /vc*
Re: Factory reset
Hello guys,
I am new to Alcatel Lucent switches. Please i need someone to help me with step by step guides on how i can reset Omniswitch 6860 to factory default. I bought these switch 6860 used and not reset to factory default but still boot to point in which it asked me for user name and password of of previous company using it.
I will be looking forward to you guys quick help.
Re: Factory reset
Hi all,
I have the similar issues any assistance will be appreciated
