BOOT Error (313)
NathJam
BOOT Error (313)
Post by NathJam »
Is anyone able to assist me?
I have a SAS-D 7210 that will not boot up or allow me to interrupt the boot process in order to reach config CLI.
This is the entire boot process:
Alcatel-Lucent 7210 Boot ROM. Copyright 2009-2014 Alcatel-Lucent.
All rights reserved. All use is subject to applicable license agreements.
Testing ROM load area...done
Relocating code...Jumping to RAM
Performing second stage RAM test....passed
Board Serial Number is 'NS1646C0883'
Bootlog started for Version D-V-8.0.R3
Build V-8.0.R3 bootrom/mpc 7xxx
Built on Mon Nov 30 12:21:17 IST 2015 by builder in /home/builder/8.0B1/R3/panos/main
?Golden bootstrap has been requested
Attempting to load Golden Bootstrap image
Version L-8.0.R3, Mon Nov 30 13:00:55 IST 2015 by builder in /home/builder/8.0B1/R3/panos/main
text:(5480960-->18823004)
 ERROR: Failed to decompress section text -- (313)
Tim loader failed
[Boot]:
The options in CLI are:
[Boot]: ?
 ?                     - print this list
 @                     - load boot.tim from flash disk and run
 %                     - load golden bootloader image and run
 R                     - full RAM test
 T                     - Manufacturing utility to format filesystem
 p                     - print boot params
 c                     - change boot params
 l                     - load boot file
 g adrs                - go to adrs
 d adrs[,n]            - display memory
 m adrs                - modify memory
 f adrs, nbytes, value - fill memory
 t adrs, adrs, nbytes  - copy memory
I have tried a 'T' manufacturing format of the filesystem but then when I try to load the system again it does the same thing.
Any suggestions would be appreciated.
Thanks,
lo0
Re: BOOT Error (313)
Post by lo0 »
That's the VxWorks OS. Enter '@' to boot the system, but eventually you'll have to get a new box... looks like the ROM is partially corrupted.
Return to “7210 SAS”
