issue in netadmin(Not recieving ping from role IP)
raza
Post by raza »
Hello Guys,
i am facing a problem in managing a netadmin. i am creating a simple netadmin of OXE Crystal in CPU redundant mode but not able to ping a role IP. Following are the Details of IP Scheme.
CPU A: 172.16.5.241
CPU B: 172.16.5.242
Role: 172.16.5.243
I am creating in the way,on CPU A
netadmin:y
IP/X25:N
Internal Name resolver:N
Node: 0(Default)
CPU Position:xa000000
IP:172.16.5.241
Netmask: 255.255.0.0
Name for role: Xma000000
IP:172.16.5.243
Redundant CPU Address: 172.16.5.242
Twin CPU Name:Xma000000
Address:172.16.5.243
Gateway:No
ON CPU B
netadmin:y
IP/X25:N
Node: 0(Default)
CPU Position:xb000000
IP:172.16.5.242
IP:172.16.5.243
Redundant CPU Address: 172.16.5.241
Gateway:No
I am not recieving a ping from role IP. While i am recieving a ping from both CPU,s.
Please HELP........................
oldboy
Re: issue in netadmin(Not recieving ping from role IP)
Post by oldboy »
So is the OXE running in Main/Standby??? run twin
Did you reboot after you changed all the IP addresses on the system, run a ippconfig option 1 and see what address is in there
Return to “ON SITE TROUBLES”
