Voip OXO - OXE "No commom codec"
Isalcatel
Post by Isalcatel »
Hi guys,
i have a client that has an OXE and an OXO with a problem in the voip calls, even been a p2p connection.
I know that OXE only uses the G729_20 codec and I realise the following things:
- If i select the same codec (G729_20) on OXO when calling and answering OXE the OXO ends the call automaticaly as soon as it is answered even there is conversation. But OXE can contact OXO normaly with no problem.
- If i select any other codec, the OXO can call OXE and it is answered and have conversation, but when OXE call OXO the OXO reject the calling with the "No commom codec" message.
OXO release: BR710/064.002
OXE release: R10.0
What should I do? Does someone has the same problem?
Re: Voip OXO - OXE "No commom codec"
H323, SIP, traces?
fery_s
Post by fery_s »
"I know that OXE only uses the G729_20 codec and I realise the following things"
who said this? depends on your configuration and your licenses it may be G711, G723 or G729.
Isalcatel
Post by Isalcatel »
vad wrote: 17 Jan 2019 22:20H323, SIP, traces?
We're using SIP.
I did the trace in .pcap format and the unleashed doesn't accept this format to attach here is the link to dowload the latest trace i did, if you want.
In the 2 first packets It was using G711_20 as a test. The next 2 was G729_30. The remaining are using G729_20.
Isalcatel
Post by Isalcatel »
fery_s wrote: 21 Jan 2019 07:11 "I know that OXE only uses the G729_20 codec and I realise the following things"
Oh, sorry. Here we use just G729_20 in our OXE clients.
fery_s
Post by fery_s »
where did you set your codec g729? did you set it in sip TG?
Return to “Networking”
