need A4400 R3.2 c1.714-3-l-fr-c3s2
anisbou
Post by anisbou »
hi
i need the release R3.2-c1.714-3-l-fr-c3s2
Re: need A4400 R3.2 c1.714-3-l-fr-c3s2
The oldest release I found on the BPWS is R5.1
You are out of luck. Time to upgrade... or duplicate your standby CPU if you have one.
I have c1.714.3af.
anisbou
Post by anisbou »
thank you vad
shuyb
Post by shuyb »
i also need one
Return to “Software Loading”
