I have a FreeNAS box to be used as a storage appliance. Two of its 10GBASE-T ports are connected to a OS6900-T20 switch, for which I intend to do linkagg.
Following the example in the Network Configuration Guide, I configured the switch as such.
linkagg lacp agg 2 size 2 actor admin-key 5 name "FreeNAS"
linkagg lacp port 1/1 actor admin-key 5
linkagg lacp port 1/2 actor admin-key 5
bxe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO>
ether 20:67:7c:01:3a:c8
hwaddr 20:67:7c:01:3a:c8
nd6 options=9<PERFORMNUD,IFDISABLED>
media: Ethernet autoselect (10Gbase-T <full-duplex>)
status: active
bxe1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO>
hwaddr 20:67:7c:01:3a:cc
status: active
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO>
inet 10.40.3.1 netmask 0xffff0000 broadcast 10.40.255.255
status: active
groups: lagg
laggproto lacp lagghash l2,l3,l4
laggport: bxe0 flags=0<>
laggport: bxe1 flags=0<>
-> show linkagg
Number Aggregate SNMP Id Size Admin State Oper State Att/Sel Ports
2 Dynamic 40000002 2 ENABLED DOWN 0 2
-> show vlan
vlan type admin oper ip mtu name
1 std Ena Ena Ena 1500 VLAN 1
4094 mcm Ena Dis Dis 9198 MCM IPC
-> show vlan members
vlan port type status
1 1/3 default inactive
1 1/4 default inactive
1 1/5 default inactive
1 1/6 default inactive
1 1/7 default inactive
1 1/8 default inactive
1 1/9 default inactive
1 1/10 default inactive
1 1/11 default forwarding
1 1/12 default forwarding
1 1/13 default forwarding
1 1/14 default forwarding
1 1/15 default forwarding
1 1/16 default forwarding
1 1/17 default forwarding
1 1/18 default forwarding
1 1/19 default inactive
1 1/20 default inactive
1 2/1 default inactive
1 2/2 default inactive
1 2/3 default inactive
1 0/2 default inactive
Thanks in advance!
