Multicast configuration point of view
plegrand
Post by plegrand »
I'm trying to configure multicast on OS6250 and OS6450 to use imaging soft (ghost or fog)
Does this config : http://plegrand1.free.fr/multicast%20config.png is ok to make it works ?
I add this command on the querier switch : ip interface Querier address 192.168.39.244 mask 255.255.255.0 vlan 2
Thanks for your help
Re: Multicast configuration point of view
it seems okay. Try it :)
plegrand
Post by plegrand »
Thanks a lot for your answer silvio.
I will try and will come back to tell if it's ok
plegrand
Post by plegrand »
Hello Silvio,
to test my configuration multicast i made this :
On all the switchs :
ip multicast vlan 2 status enable
ip multicast vlan 2 zapping enable
ip multicast vlan 2 version 3
ip multicast vlan 2 querier-forwarding enable
On the querier switch (where the ghost server is) in addition to previous command
ip multicast vlan 2 querying enable
It didnt works.
My question is the following :
Do i have to also made this command globally ?
And then, do i have to disable all of these commands on all vlans except in vlan 2
Thanks for your answer
plegrand
Post by plegrand »
http://plegrand1.free.fr/IGMP.png
Does this configuration can impact the wake on lan packet ?
plegrand
Post by plegrand »
Here is the configuration i made without success.
Multicast is very slow and i cant understand why.
All switchs
ip multicast status enable
ip multicast zapping enable
ip multicast version 3
ip multicast querier-forwarding enable
Querier Switch
ip multicast querying enable
Disable IGMP on all vlans except vlan 2
All switchs
ip multicast vlan 1 status disable
ip multicast vlan 3 status disable
ip multicast vlan 998 status disable
ip multicast vlan 999 status disable
ip multicast vlan 1 zapping disable
ip multicast vlan 3 zapping disable
ip multicast vlan 998 zapping disable
ip multicast vlan 999 zapping disable
ip multicast vlan 1 querier-forwarding disable
ip multicast vlan 3 querier-forwarding disable
ip multicast vlan 998 querier-forwarding disable
ip multicast vlan 999 querier-forwarding disable
ip multicast vlan 1 querying disable
ip multicast vlan 3 querying disable
ip multicast vlan 998 querying disable
ip multicast vlan 999 querying disable
Querier Switch
ip multicast vlan 29 status disable
ip multicast vlan 30 status disable
ip multicast vlan 31 status disable
ip multicast vlan 32 status disable
ip multicast vlan 35 status disable
ip multicast vlan 36 status disable
ip multicast vlan 99 status disable
ip multicast vlan 1000 status disable
ip multicast vlan 29 zapping disable
ip multicast vlan 30 zapping disable
ip multicast vlan 31 zapping disable
ip multicast vlan 32 zapping disable
ip multicast vlan 35 zapping disable
ip multicast vlan 36 zapping disable
ip multicast vlan 99 zapping disable
ip multicast vlan 1000 zapping disable
ip multicast vlan 29 querier-forwarding disable
ip multicast vlan 30 querier-forwarding disable
ip multicast vlan 31 querier-forwarding disable
ip multicast vlan 32 querier-forwarding disable
ip multicast vlan 35 querier-forwarding disable
ip multicast vlan 36 querier-forwarding disable
ip multicast vlan 99 querier-forwarding disable
ip multicast vlan 1000 querier-forwarding disable
ip multicast vlan 29 querying disable
ip multicast vlan 30 querying disable
ip multicast vlan 31 querying disable
ip multicast vlan 32 querying disable
ip multicast vlan 35 querying disable
ip multicast vlan 36 querying disable
ip multicast vlan 99 querying disable
ip multicast vlan 1000 querying disable
You can do your commands global or per vlan - it is the same in your case. You have an ip interface at the querier. So only in this vlan 2 the multicast traffic should be forwarded. But I never used the "version 3" command. Normaly we use per default version 2 (IGMP). I am not sure what occoures if your MC clients are sending IGMPv2 Packets. But you can find it out if you delete this line in all your switches.
Have you checked the querier status at all your switches: show ip multicast querier
and all your MC traffic: show ip multicast source/forward/group ..... ?
plegrand
Post by plegrand »
Thanks Silvio for your answer, i will make tests with IGMP V2.
Thanks again
Return to “OmniSwitch 6450”
