How can I get the latest CPU usage of OS10K via SNMP?
fkromer
Die SNMPv2-MIB::healthDeviceInfo.healthDeviceCpuLatest (1.2.1.16.1.1.1.13) konnte bei älteren Switches verwendet werden, um die latest CPU usage abzufragen. Das OS10K kann darüber aber nicht abgefragt werden. Gibt es eine UID um die latest CPU usage abzufragen und falls ja welche?
Re: How can I get the latest CPU usage of OS10K via SNMP?
Please ask your questions in english. Within all the cli guide you will find at every command the correct MIB object.
in this cas you are looking for healthModuleCpuLatest (the same for all R8 switches).
To get the oid use this command:
best regards
> show snmp object identifier healthModuleCpuLatest
1.3.6.1.4.1.6486.801.1.2.1.16.1.1.1.1.1.15Silvio
fkromer
Hi Silvio, thanks for the fast response. I'll replace the copy&pasted question with a english one. Could you hyperlink the cli guide and refer the relevant page please?
Here the way to find the docus. https://www.al-enterprise.com/en/products/switches
For OS10k is it the same like for all other R8 switches (f.e. OS6860)
And here the link to the cli-guide:
https://www.al-enterprise.com/-/media/a ... 2_reva.pdf
You will find the mibs at every command by yourself
best regards
best regards
fkromer
The command show "snmp object identifier healthModuleCpuLatest" does only work in case I have access to switch I guess?
Yes, but you can do it at all R8-Switches.
fkromer
I am implementing the request of OS10K data for a monitoring server. I don't have the device available physically. How can I get info about OIDs, etc. best then? (I have snmp walks which could potentially be partial.)
fkromer
healthModuleCpuLatest works perfectly fine. Thx.
