Lanpower problems on 6350
- thermseeker
Hi all,
Please see if you can help me with this...
6350-P24 and -P48 units stop feeding power to a group of 8 ports after a power cycle. I saw this happen twice, on a -P24 about an year ago, and on a -P48 yesterday. On the -P24 I tried reboot, power cycle, firmware update but nothing helped. Also no errors during the startup on in the logs. I concluded I had a hardware fault, and after a few weeks when I was preparing to replace and send it to tech support I retested the bad ports and they were back to normal. On the -P48 I did a power cycle a few minutes ago and no go. I'm gonna wait a few weeks and retest.
Both times the ports were feeding A-L APs IAP-103 and/or Aastra 7433ip IP phones. Both loads are much below the max for each port. The power sources are 525 W on the -P24 and 915 W on the -P48 no lack of power is not an issue.
I have several 6450-Pxx here but never had an issue with those.
This is very weird, has anyone seen this? Thank you in advance for any reply.
Tales Maschio
thermseeker
Tales Maschio
thermseeker
Re: Lanpower problems on 6350
This was a known issue. You have to update the switches to an actual release (maybe also the uboot).
best regards
best regards
- thermseeker
I think I’m on the latest version. Not sure about the uboot tho. Will check. Many thanks.
tales
tales
- thermseeker
Hello! Wish you all a happy 2019!
Updated all switches (~30) in this site to latest available AOS/uboot-miniboot/FPGA. On the 6350s "show ni" shows that the POE SW version was updated. So maybe this issue is gone.
Thank you Silvio.
Tales
Thank you Silvio.
Tales
Thanks for the successfull reply.
Mohammadlinux
I was update the OS to OS6350_6.7.2.113.R05 also OS6350_6.7.2_R02_Uboot_Miniboot and OS6350_6.7.1.146_FPGA but not solved.
Is there POE SW version update?
any idea?
any idea?
- thermseeker
Hello Mohammad,
The POE SW version comes updated with uboot-miniboot or FPGA (not sure which), there is no separate file for it. On my firmware files the versions for uboot-miniboot and FPGA are both OS6350_6.7.2_R05, which look newer than yours.
Check your versions with "show microcode" and "show ni". Here the output for one of my 6350 units:
Tales
> show microcode
Package Release Size Description
KF3base.img 6.7.2.113.R05 16582339 Alcatel-Lucent Enterprise Base Softw
KF3os.img 6.7.2.113.R05 3698036 Alcatel-Lucent Enterprise OS
KF3eni.img 6.7.2.113.R05 6634341 Alcatel-Lucent Enterprise NI softwar
KF3secu.img 6.7.2.113.R05 621210 Alcatel-Lucent Enterprise Security M
> show ni
Module in slot 1
Model Name: OS6350-P24,
Description: 6350 24 PORT COPPER GE POE ,
Part Number: 903794-90,
Hardware Revision: 15,
Serial Number: xxxxxxxx,
Manufacture Date: DEC 20 2015,
Firmware Version: ,
Admin Status: POWER ON,
Operational Status: UP,
Power Consumption: 19,
Power Control Checksum: 0x1716,
CPU Model Type : Marvell PJ4B (584) v7 (Rev 2),
MAC Address: xx:xx:xx:xx:xx:xx,
ASIC - Physical 1: Alleycat3,
FPGA - Physical 1: 0016/00,
UBOOT Version : n/a,
UBOOT-miniboot Version : 6.7.2.113.R05,
POE SW Version : 23.0211.26
Tales
Mohammadlinux
Hi,I was update to the last version.This is output command:
But Not Solved!!!
->show microcode
KF3secu.img 6.7.2.113.R05 621210 Alcatel-Lucent Enterprise Security MCode: Select all
-> show ni
Module in slot 1
Hardware Revision: 16,
Serial Number: U37Q0198,
Manufacture Date: SEP 16 2016,
Firmware Version: ,
Power Control Checksum: 0xf99c,
MAC Address: 2c:fa:a2:5d:55:68,
POE SW Version : 23.0211.26Code: Select all
-> show hardware info
CPU Type : Marvell PJ4B,
Flash Manufacturer : Micron Technology, Inc.,
Flash size : 134217728 bytes (128 MB),
RAM Manufacturer : Samsung,
RAM size : 268435456 bytes (256 MB),
Miniboot Version : 6.7.2.113.R05,
Product ID Register : 0b
Hardware Revision Register : 31
CPLD Revision Register : 16
-> show configuration snapshot lanpower
! Lan Power :- thermseeker
Hi Mohamad,
What exactly is wrong with your 6350?
Mohammadlinux
6350-P24 stop feeding power to a group of 8 ports(port 1 to 16) after a power cycle. Just port 17 to 24 is OK!
