OXO - OXO with VPN
boht
OXO - OXO with VPN
Post by boht »
Is possible interligation OXO-OXO (Connect R2.1) only VPN? Nothing use external gateway.
Re: OXO - OXO with VPN
Well your router will do the vpn routing right? So actually the media used (WiFi, mpls, etc) is up to you.
luanmartins1
Post by luanmartins1 »
Na verdade, Gostariamos de saber se faz sem usar um roteador ou algo do tipo... Apenas oxo para oxo via VPN pela propria central. No caso a nova connect R2.1.
No. You can't.
OXO doesn't have inner VPN capabilities.
Favor posta em inglês. O fórum é pra todos.
Return to “Networking”
