Is there any way to select what to be appeared in a 4029 set when somebody calls this set?
Now, the calling name is appeared in the display and Customer want the calling number to be appeared instead of name.
OXE R 10
thank you
Alex
4029 - Internal Callling number appeared to 4029 set, instead of calling name.
alexandros_z
Re: 4029 - Internal Callling number appeared to 4029 set, instead of calling name.
no.
but as a workaround, you can modify the display name of the calling set.
regards...
regards...
alexandros_z
Not sure (I can't check) - Phone feature COS - item "Virtual set on CMP board".
You will see - or only name, or only number - not remember.
changing virtual set on cmp board worked, is it possible to also show the names after the number?
