Hello, i need to know if valid apply license on virtualchassis OS6900 (4 switches) running on fly or i needit shutdown the switch dettach of virtualchassis and apply license alone.
apply license with virtual chassis running? it's valid.
devnull
Re: apply license with virtual chassis running? it's valid.
you can apply the license while in the vc (if you put all licence for all vc switches in the same file it should update all switches) Licences may require a reboot to become active thou
stunshot
Hi, on latest firmware no licence is needed for Advanced routing (to buy) just a blank licence.dat file in flash directory
lorenacrisan
To activate the perf license for ports 10 on an OS6360 virtual chassis, what is the process?
