Automatic POE on Startup
Hi all, I am brand new to this forum and brand new to the world of Alcatel switches. I have multiple OS6450-P24 and P48 switches. I took over this job from my predecessor about 30 days ago and still learning so pardon me if I seem like I am asking novice questions. I have a brand new switch that was in storage, not sure when it was bought but it was never put online until a weeks ago. I got it configured but POE was not working, after some reading I used the "lanpower start" command and POE started no problem, as soon as I took the switch from the lab to the closet i was putting it in the POW stopped working until I hooked up a console cable and typed in the command again. is there a way to run that command upon boot-up so I don't have to type it in all the time if the power goes out. I only have 3 Accesspoints I want to run from the one switch. thanks in advance for your help.
devnull
Re: Automatic POE on Startup
have you saved the config after you configured lanpower start?
try
"write memory flash-synchro"
Check if the config persists after power cylce - it should
try
I did save the config after executing the command, but I used
copy certified working
write memory
copy working certified
I will try your write memory command, Thanks
write memory
devnull
Write memory flash synchro
should be enough to store the current running config into working and certified.
download the config in working/certified and verify that the lanpower command is there.
that worked like a champ, thank you for all the help
