Hello
I did a new OTMS installation, but I think that at the time of entering the password of the root users was not correct, because I am trying to connect via SSH and it is giving remote access, but if using the user otuser to work.
How can I reset this password?
thank you
Reset Root password.
Re: Reset Root password.
You cannot use root from ssh, you must use otuser the use su- and enter root password.
It can be enabled to use root but i wouldnt advise it
can you tell me how I enabled to use root via SSH?
I found nothing in the manuals.
thank you.
thank you.
http://lmgtfy.com/?q=ssh+root+login+suse
Wont be in the manuals as ALU dont recommend it
I strongly agree to this!oldboy wrote:Wont be in the manuals as ALU dont recommend it
But if you wanna do it... it is easy to find in the www...
And also it ist easy to find, why you must NOT enable directly root login from network protocols...
Again, this points us to the three basic lessons:
Stay away from guessable passwords
Watch for weird files (stuff you didn't put there yourself) anywhere in your file system, even in /tmp.
Internalize the fact that PermitRootLogin yes is a bad idea.
http://bsdly.blogspot.de/2013/10/the-h ... d.html?m=1
regards...
