LACP - linkagg Testing
jpattard
Post by jpattard »
I configured LACP on a Stack of two OS 6350-24. If i disconnect 1 of the ports the link is still working, but if i remove both ports and put them back after a few seconds it does not get back up. Below is the config on these switches.
-> show linkagg
Number Aggregate SNMP Id Size Admin State Oper State Att/Sel Ports
1 Static 40000001 2 ENABLED UP 2 2
Slot/Port Aggregate SNMP Id Status Agg Oper Link Prim
1/2 Static 1002 ATTACHED 1 UP UP NO
2/2 Static 2002 ATTACHED 1 UP UP YES
-> show 802.1q 1
Tagged VLANS Internal Description
2 TAG AGGREGATE 1 VLAN 2
100 TAG AGGREGATE 1 VLAN 100
Re: LACP - linkagg Testing
You haven't configured LACP. Your LAG is static. I recommend to reconfigure both switches with LACP and try again.
jpattard
Post by jpattard »
In the mean time have reconfigured the switch with dynamic LACP but it still takes time to failover to the other switch. See config below:
! Port Mapping :
! Link Aggregate :
lacp linkagg 1 size 2 admin state enable
lacp linkagg 1 actor admin key 1
lacp agg 1/2 actor admin key 1
lacp agg 2/2 actor admin key 1
! VLAN AGG:
! 802.1Q :
vlan 2 802.1q 1/1 "TAG PORT 1/1 VLAN 2"
vlan 100 802.1q 1/1 "TAG PORT 1/1 VLAN 100"
vlan 2 802.1q 1/3 "TAG PORT 1/3 VLAN 2"
vlan 100 802.1q 1/3 "TAG PORT 1/3 VLAN 100"
vlan 2 802.1q 1 "TAG AGGREGATE 1 VLAN 2"
which device is at the other end of the linkagg? Have you configured there also LACP?
Return to “OmniSwitch 6350”
