Alcatel Omniswitch 6850E load module PIM
investor333
Post by investor333 »
Hello! Help solve the problem. It is necessary to configure the Omniswitch 6850E PIM, but I can not load the module. The instructions say that to load the module, you need to run the command: ip load pim. But I have an error: ERROR: Unable to load necessary IPMRM module
Firmware S6850E AOS 6.4.4.343 R01
-> ip load pim
ERROR: Unable to load necessary IPMRM module.
Help me please!
Re: Alcatel Omniswitch 6850E load module PIM
did you have installed the advanced routing packet? It is a file named Kadvroute.img (or similar) in your working directory.
investor333
Hi, Silvio.
No, the extended routing package did not install, I did not find it anywhere. I wanted to register, on the business portal Alcalel, it did not work, writes:The domain of your email address does not match the domain names allowed by your company. Make sure to use an appropriate domain name. Tell me where you can get this package, thank you.
you need help from an alcatel partner. Ask the supplier of the switches.
