Conferencing
link
Conferencing
Post by link »
We have installed OTMS version 2.31 and already configured for conferencing service. To manage conferences we are using MyTeamwork Gui client (webclient) not OTC.
OTMS configuration was created via OmniVista 8770 and ACS via OTMS WedAdmin.
The main issue is when conferencing was created and the necessary participants were added (for exampe, 5 participants in conference) invite is formed not to all. Sometimes the system doesnt form a call to one or more participants.
I have make siptace on the OXE side and dont see an invitation from Sip proxy OTMS.
Can any one suggest to me what should I look in additional or do.
Thanks.
Re: Conferencing
Check dialing rules at teamwork.
link
Re: Conferencing
Post by link »
You mean DAS rule?
But temwork make calls participants which in the same dialing format.
Re: Conferencing
Yeah, then check TW logs and specially SIP ones.
Just double check your rules.
Can you call them manually via the conference room?
link
Re: Conferencing
Post by link »
Yes, from established conference
For example, 20101,20102,20103,20104 - were invited and 20105 and 20106 didn't
Re: Conferencing
Ok then check teamwork logs to see if any error raises on logs
link
Re: Conferencing
Post by link »
More additional information,
1. PBX Numbering Plan 5 digits
2. Directory number begin with 2
3. Prfixes for outgoing calls are 0,00 where 0 - for National, Local Calls and 00 - for International calls
Configured DAS rule,
DAS Rule 1 - s/^\+[xX]?(\d{3,6})$/\1/
DAS Rule 2 - s/^\+(\d{3,6})$/+x\1/
DAS Rule 3 - s/^[\+]?x//
DAS Rule 4 - s/^\+380/00/
DAS Rule 5 - s/^\+M/M/
DAS Rule 6 - s/^\+N/N/
DAS Rule 7 - s/^\+V/V/
DAS Rule 8 - s/^\+/00/
Configured Phone Formatting Rules,
/^\s*\+*[xX]?(\d{3,6})\s*$/
link
Re: Conferencing
Post by link »
I got logs (SipServer.log) and when conference was created and started participant 20101 were not invited.
In SipServer.log I saw:
[WARN] csta: CstaMonitorManager::CreateDeviceMonitor - deviceNumber 20101 NOT FOUND
[INFO] csta: CstaMonitorManager::CreateDeviceMonitor - Monitor for deviceNumber CBA is created, refId=1
Information about conference:
patricipants - 20101,20105,20110.
leader - 20111.
Re: Conferencing
You have a CSTA warning...
Does that extension exists? Do you have enough CSTA licenses?
link
Re: Conferencing
Post by link »
Yes, it's IPTouch 4028 phone
I'll check
Return to “OTMS - OpenTouch Multimedia Services”
