ICS 6.7 and OXE 12.1
bouqueth
Post by bouqueth »
Is anyone outthere, who knows if ICS 6.7 and OXE 12.1 is functional together?
I will Upgrade my OXE in Q2-2018 to Release 12.1 and need all functions from our ICS 6.7 installation.
Thanks for every comment.
Harry
Re: ICS 6.7 and OXE 12.1
I would say test it, by ALE it is not compatible.
Maybe some SIP changes could affect it but depends on what exactly you are using.
Search for the compatibility doc. I remember I have seen it and according to it ICS 6.7 is no longer compatible with R12. Also in Actis you are forced to remove it... Of course if you use old types of phones you can still test (maybe no issues) as Cav suggested.
mgoegel
Post by mgoegel »
I would not expect, that it would work together.
There is a important change on the CSTA interface in R12.1, therefore the older OT (less than 2.2.1) will also not work.
Regards Mario
Gesendet von iPad mit Tapatalk
mgoegel wrote: 11 Mar 2018 04:22 There is a important change on the CSTA interface in R12.1
Any details?
mgoegel
Post by mgoegel »
Authentication needed for the CSTA bypass.
Ohhh that is quite a change
New TSAPI then?
mgoegel
Post by mgoegel »
cavagnaro wrote: 12 Mar 2018 07:55 Ohhh that is quite a change
New TSAPI then?
That's a good question. Have not looked for it.
Just mentioned it on a test and looked a little deeper. ;-)
I also found no docs on this change.
Regards Mario
