cannot install release 9.1 in CPU Appliance Server
fahmi
Post by fahmi »
Dear Support,
Our Customer used alcatel OXE release 9.0 and will be upgraded to release 12.0. Our customers use the IBM Appliance server. When I want to install to release 9.1, no activity happens( Stack ), I am using 80 gybyte hdd. Please help as soon as possible ...
But If i install release 11.0 is working fine.
fahmi
alexeik
Re: cannot install release 9.1 in CPU Appliance Server
Post by alexeik »
why do you want to install r9.1?? normally you get new appliance server when you do an upgrade to R12
imran
Post by imran »
Dear Support,
As i am trying to install the ESXi on Appliance Server 2G0 HP unfortunately no luck could you please guide me which version of Esxi will support for this appliance
imran
Post by imran »
When i try to install the esxi on my server i am getting error as Media test Failure check cable , PXE-MOF: Exiting PXE ROM i cross check in BIOS setting as the Hard disk on boot sequence number 1 could you please update me any one which rea are the settings to be done from my side
2 nd issue
I try to load from Network boot its getting error Uncompressing Linux.. OK Booting the kernel
waiting for your favorable response on this
Omni PCX enterprise Application Server 2Go HP this is the server model
Return to “Software Loading”
