busy when no free agents
marcin99
Post by marcin99 »
Is it possible that configuration?:
Incoming call: Pilot->Queue->PG-> Free Agent
if no free agents: Pilot->Busy Signal or Pilot->Queue->Busy Signal
Re: busy when no free agents
Change the tone at the pilot?
sadim
Post by sadim »
Check the parameter "Dissuasion Busy Tone On DDI" on the pilot attributes
marcin99
Post by marcin99 »
I have enabled this option and receive busy signal only when no agent logged in or when all agents have withdrawal status, but no when all agents are busy (have calls)
sadim
Post by sadim »
Thats normal if you have on the queue the max waiting time > 0. You need to set the queue max waiting time to zero.
Or change the waiting guide to the busy guide
sadim
Post by sadim »
With my solution, external user will not pay to ear the busy ton. This is a major difference.
Enviado do meu WAS-LX1A através de Tapatalk
Return to “4760”
