i got .cdb files for OXO systems, i need to know how to convert them to .oxo files?
how to convert .cdb file to .oxo file in offline mode?
Re: how to convert .cdb file to .oxo file in offline mode?
you cannot convert it, you can open the cdb with omc, and export the .oxo
So how can i do it on OMC?
open it, open the file and choose import/export, then data type "oxo actis".
choose the path and name for the file and click export on the right...
sir, i did the following steps, so correct me if i was wrong:
- on OMC (offline)->File -> backup -> restore -> select the .cdb file.
- on OMC (offline) -> file-> Open
-on OMC(offline) -> Open database window-> select the .cdb file and double click on it
- i got the following message popup-> click yes
OMC
You are trying to load a database that was saved for
target product 3EH30534ARAA OMC10.2/18.1a.
The actual target product is 3EH30546ARAA OMC21.0/16.1a
The database may not be readable
Load anyway?
Yes No
- after clicking yes for above pop window message, i got another one as following, so i click OK:
OMC
Please, install the external tool : DBAdapter
OK
- in Import\export->select OXO actis and choose the where to export the file.
- after exporting the file, i trying to add it in Actis but i got the following error
Error
Invalid file: D:\ALE\Customer\syssense-UAE-DWA\test.oxo
Ctrl+C' copies the error messages to the clipboard
OK
thanks to help with another means.
- giovanni.attolini
install db adapter before open cdb file
Giovanni A. Attolini
To convert a .cdb file to a .oxo file in offline mode, you need a compatible software or tool that supports both formats. First, ensure the .cdb file is not corrupted and backed up. Then, use a converter utility or script that can read .cdb format and export or save it as .oxo. Make sure the conversion retains data integrity, especially when dealing with structured or encrypted content. nulls brawl
I had that same DBAdapter issue before. Once I installed it, everything worked fine and the export went through without problems. Bit of a hassle at first, but it does the trick once it's all set up. Nulls Brawl iOS
