4035 Attendant "Beep"
johank_DUP
Post by johank_DUP »
When using a 4035 as an attendant set... While the Att is busy on a call, on the next incoming external call, the 4035 set will make a "beep" sound to indicate there is a call waiting.
Is there any way to extend or change that "beep"?
I have checked the manual and cannot find anything on this?
Any help would be appreciated. Tnx
Re: 4035 Attendant "Beep"
As far as I know you can enable or disable that beep in Phone feature COS--->protection against Over ringing YES.
Regards.
johank_DUP
Yeah, turning it off is possible but you can't seem to change it.
The client says the beep is not enough for them. They don't always hear it.
I don't think its possible...
Some of my clients complain about not understanding the other party when beeping :lol:
Depends on the client :lol:
Return to “Users”
