Remote access to VM in OXO blocked
omarsg1977
Post by omarsg1977 »
Hi, i have an OXO in R7.1 with de remote access to the VM locked. The client put the wrong password several times and the mailbox is locked, I have reset the password and the mailbox is now accessible but when I try to listen the messages gives me a locution that says "remote access to the mailbox is blocked" and does not leave me listen. Does anyone know what can I do?
PuGZopf
Re: Remote access to VM in OXO blocked
Post by PuGZopf »
HI you,
this is a feature against Hacking the VoiceMail.
If you check the VM from the Phone local, the VM is unlocked with only hear you VMs. The Message you wrote is only a hint, that someone locked the VM from outside.
You can delete the message. Your Vm is correct working.
Its since 7.1 56.00x I think
Return to “Configuration”
