OmniVista 8770 R3.0 error to add Sip device
This application replaces the OmniVista 4760
manoj
Post by manoj »
I have installed 8770 R.30 with my OXE 11.2. synchronization is working fine.
I want to configure 8088 handset with my OXE. So in USER tab on 8770 when I am associating a SIP device with user 8770 is giving below error.
"Retrieve user entries 'Uid=123 Test,o=FIT,o=directoryRoot' error: Connection refused: connect"
rolfo333
Re: OmniVista 8770 R3.0 error to add Sip device
Post by rolfo333 »
Could you check whether the Apache service is running on your 8770 server?
Br,
rolfo
manoj
Post by manoj »
Apache is showing error. attached the image.
hope port 80 is used by another application.
rolfo333
Post by rolfo333 »
I assume you need to uninstall IIS (which is currently using the port):
http://www.c-sharpcorner.com/UploadFile ... rver-2012/
Br,
rolfo
manoj
Post by manoj »
Thanks...Its working now...
morio
Post by morio »
hi, its a known issue, delete the oxe tree in 8770 and recreate it, synchronize it,, it will work,,,, it happen to me as well
Return to “OmniVista 8770”
