Trunk Supervision doesn't work for outgoing calls
diegopcsilva
Post by diegopcsilva »
Good night people,
I'm new to telephony, I've been servicing an MD110 PBX for 3 years and for the past 3 years I've been working with Alcatel OMNI PCX Enterprise OXE(R10.0). Yes, I searched the forum and the manuals that I have for the solution that I need (maybe I do not know exactly what to look for), and other than that I'm always reading the topics to try to learn something new.
My problem is: I have several Trunk Groups (TG), due to having to receive several different branch extensions. My TG 3 works perfectly, but my TG 5 works partially. How partially? When I create a trunk in this group (TG 5) and program the corresponding Trunk Number on a key on a digital extension, I can receive a call normally and if I happen to use the TG 5 access code and access that trunk I can also do call. But if I try to access the trunk by the key through Trunk Supervison, I get the following error message: Feature Rejected.
I usually use analog extensions from the Alcatel PBX itself on TG 3, and TG 5 i use analog extensions from an old MD110 PBX, although if I take a trunk from TG 3, I kill it and recreate it as TG 5, the defect continues on TG 5. And if you delete a trunk of TG 5 and create it as being from TG 3, this trunk normally works by the key.
This obviously leads me to believe that there is a configuration problem on my TG 5, but I've looked back and forward and found no difference. Even creating a new TG with the same features and settings as TG 3 and the result was The same as TG 5.
So,I know that if use all analog extesion on TG 3, will work, but i wish if possible to keep separeted.
Hope i made myself clear,I will put below the settings of both TG.
Thank you and I'm sorry for my english.
Any Tips?
Could be license?
┌─[ 14 ] Instances: Trunk Groups─┐
│ -> 1 │
│ 3 │
│ 4 │
│ 5 │
│ 6 │
│ 7 │
│ 9 │
│ 10 │
│ 11 │
│ 13 │
│ 14 │
│ 15 │
│ 16 │
│ 19 │
┌─Consult/Modify: Trunk Groups─────────────────────────────────────────────────┐
│ Trunk Group Id : 3 │
│ Trunk Group Type + NDDI (BCA) │
│ Trunk Group Name : Rede 1 │
│ UTF-8 Trunk Group Name : ---------------------------------------│
│ Number Compatible With : -1 │
│ Remote Network : 15 │
│ Shared Trunk Group + False │
│ Special Services + Nothing │
│ Node number : 1 │
│ Transcom Trunk Group + False │
│ Auto.reserv.by Attendant + False │
│ Overflow trunk group No. : -1 │
│ Tone on seizure + True │
│ Private Trunk Group + False │
│ Paging Trunk Group + False │
│ Paging Table Id : -1 │
│ Paging Signalization + NDDI │
│ Security Patrol + False │
│ Prefix Sending + False │
│ Number Of Digits To Send : 30 │
│ auto.DTMF dialing on outgoing call + YES │
│ DDI transcoding + True │
│ Register Signalling + Decadic/MF Q23 │
│ Implicit Priority │
│ Activation mode : 0 │
│ Priority Level : 0 │
│ Preempter + NO │
│ Incoming calls Restriction categ. : 10 │
│ Outgoing calls Restriction categ. : 10 │
│ Trunk Group Id : 5 │
│ Trunk Group Name : Rede 2 │
│ UTF-8 Trunk Group Name : --------------------------------------- │
│ Node number : 1 │
│ Number Of Digits To Send : 7 │
│ Preempter + NO │
┌─Select an object─────────────┐
│ Trunk Group │
│ -> Trunk Group NPD Selector │
┌─Consult/Modify: Trunk Group NPD Selector───────────┐
│ Instance (reserved) : 1 │
│ Public NPD id : 3 │
│ Private NPD id : 0 │
│ Management Mode + Automatic │
│ Public DDI transcoding + True │
│ ->Trunk Group │
│ Trunk Group NPD Selector │
┌─Consult/Modify: Trunk Group──────────────────────────────┐
│ T2 Specificity + None │
│ Public Network Ref. : ------ │
│ VG for non-existent No. + YES │
│ Entity Number : 0 │
│ Supervised by Routing + NO │
│ VPN Cost Limit for Incom.Calls : 0 │
│ Immediat Trk Listening For VPNCall + YES │
│ VPN TS % : 50 │
│ Csta Monitored + NO │
│ Max.% of trunks out CCD : 0 │
│ Ratio analog.to ISDN tax : ------ │
│ TS Distribution on Accesses + YES │
│ Quality Profile for Voice on IP + Profile #1 │
│ IP compression type + Default │
│ Use of volume in system + YES │
│ Announcement for Dialtone + NO │
│ Announcement for Ringtone + NO │
│ Reroute Anonymous Calls to Entity + NO │
│ Dialling end to end + NO │
│ DTMF end to end signal. + NO │
│ Paying Incoming Calls + NO │
│ TS Permanently assigned + YES │
│ Min. Nb.of digits on seize : 0 │
│ Trunk group used in DISA + NO │
│ DISA Secret Code : ---- │
│ Routing To Executive + NO │
│ Dissuasion For ACD + NO │
│ DTO joining + NO │
│ Automated Attendant + NO │
│ Calling party Rights category : 0 │
│ Access Cluster Id : -1 │
│ Collect Calls Allowed + YES │
│ VPN TS % : 50 │
┌─Select an object───────────┐
│ T2/T1/T0 Access │
│ -> Trunk │
│ Virtual Access for SIP │
│ Virtual access for IP │
┌─Consult/Modify: Trunk──────────────────────────────────┐
│ Physical Address : 4-21-3 │
│ Trunk Category Id : 1 │
│ Directory Name : -------- │
│ Trunk Routing Number : -------- │
│ Channel Specialization + Mixed │
│ Trunk Number : 291 │
│ Data Transparency + NO │
│ Physical Address : 5-13-3 │
│ Trunk Number : 342 │
┌─Consult/Modify: Progr.Keys────────────────────────────────────────────┐
│ Directory Number : 6767 │
│ Key No. : 6 │
│ Function + Trunk Supervision │
│ Mnemo(Pocket,Mobile,4040,8&9) : -------------- │
│ UTF-8 Mnemo (8&9 Series) : ------------------------------- │
│ Ringing Mode + Short Ring │
│ Key No. : 2 │
│ Ringing Mode + Long Ring │
Re: Trunk Supervision doesn't work for outgoing calls
did you figure this out?
diegopcsilva
frank wrote: 05 Sep 2017 17:00 did you figure this out?
Not yet. I reading the documentation: R10.0SysDoc.tar.gz.
when u kill the trunk and recreate it u dont change the physical equipment right? when u recreate it in the new tg u got the same logical number or not?
I see only two differences
one is not consistent for me number of digit to sent Tg3 open dialing tg5 only 7 digits
why are using DDI transcoding on NDDI? NDDI=NO DDI
last thing trkstat command shows that the trunk is free?!
when trksupv key is used we got feature rejected if the dial tone is not detected
diegopcsilva
Hi, Thanks for trying to figure out!
Yes, don't change the physical eqt. Same logical number.
I see the Number of Digit to Sent, good point, but both works with private numbers only(and small 4 or 6 digitis), so in this particular case don't matter.
I will try this: NDDI=NO DDI
Yes, the trunks is free.
Thank You!
haroun wrote: 25 Sep 2017 17:53 when u kill the trunk and recreate it u dont change the physical equipment right? when u recreate it in the new tg u got the same logical number or not?
oldboy
Post by oldboy »
best way i have done it is back to back the trk to an Analog extn, set supervise the Analog
Return to “Trunk Groups”
