8018 LLDP issue with HP 1920 procurve
barryo76
Post by barryo76 »
Hello guys,
Does anyone use HP procurves using LLDP. I have a POE+ 1920 which works fine.
I have just bought a non POE 1920 switch and i'm having LLDP issues with 8018 handsets. I have the data on Vlan 19 and the Voice Vlan 17. When plugging in the handset the switch assigns vlan 128. Need help...
tgn
Re: 8018 LLDP issue with HP 1920 procurve
Post by tgn »
solution 1
switch off the option lldp vlan in the phones menu (i+2 while the phone is boot in phase 1, 2 or 3)
solution 2
switch off the lldp vlan configuration in the hp1920.
regards...
Return to “Networking”
