IP desktop softphone integration with 8028
HUSSAINQCS
Can anyone tried to intergrate IP softphone with 8028 ?
Re: IP desktop softphone integration with 8028
Why would you do that?
It's like connecting a 8068 as 8028.
You will have a wrong display.
Mario
Gesendet von iPad mit Tapatalk
Mario
HUSSAINQCS
I having 8028 phone but the clients want both name and number of called party to be shown in 8028 but we have 8028 phones only
That is the reason planning to install IP softphone in the PC which is connected to the back of the IP phone
You know, that the IP Desktop Softphone will be another, different, software based IP phone?
You'll need a IP User license for this + IP DSP license. It's not a CTI/TAPI software.
The only thing, how this would make sense (if) in any matter, when you make a tandem configuration, to get the information on the PC displayed.
The customer wants an 8038. He just bought the wrong phones and/or didn't specify you, what he wants (if you sold the 8028 to him).
Mario
Mario
HUSSAINQCS
Now changed the set model from 8028 to 8068 in mgr But in the call logs I not getting the delete,recall options
so that I can get any option is it possible ?
there is no special option in 8028 to do this.
try this workarround ->
give the phone set a short name in the "directory name". then paste the phone number in the "directory first name". set this name in "can be called by name" to false. then go down and create an alias with the correct name and first name. set this alias to "can be called by name" to true.
regards...
regards...
HUSSAINQCS
Any possibility to remove the suffix *UK when calling from the room set ?
doesn't know. but there is an option in applicatons/hotel which sounds like that what you want. -> "Restrict Language code display"
maybe it helps...
regards...
maybe it helps...
regards...
HUSSAINQCS
Even the parameter is false but still I can able to see the UK suffix when room user is calling
Any option ?
Any option ?
