Hi Team
I am trying to install the OMS R12 using the bootdvd version -bootdvd.12.0.001.002.x86_64.iso on a Esxi host 5.5 , VMWARE workstation 12.5.6 as well as on esxi 6.0 . I am getting the following error " A logical volume with the requested size could not be created " and the installation fail to continue.Looking into Suse website , this seems to be a bug in Suse 11 sp1 and was corrected
So wondering if anyone else has encountered this problem and if so could you please share the resolution details?
OMS R12 - SUSE 12 Installation
rolfo333
Re: OMS R12 - SUSE 12 Installation
Do you use ALEDS to install OMS? Make sure to have the latest version if so.
Br
Rolfo
Br
Rolfo
kiwirk
Thanks Rolfo -All good
Unlike the previous Redhat bootdvd , the new R12 OMS boot dvd have several options to chose and not all of them are visible on the main screen and we need to scroll down to select OXE media server
Have attached the screen shot
hi,
i was successful on installing suse . any idea how i can install the oms in it?
thanks
thanks
wangtianxiao
Would you like to share some official guides of the OMS R12-SUSE installation?
