DHCP VLAN PROVISSIONING WITH THOMSON ST2030
This forum is for misc discussions that have nothing to do with Alcatel-Lucent.
dryhouse
Post by dryhouse »
Hello guys,
Anyone have experience with the model of subject? I´m trying to boot Ip telephone Thomson ST2030 and the customer require the provissioning the vlan with DHCP.
Regarding documentation i see the options 190, 191 and 192, but i couldn´t make it work.
Any ideas????
Thanks for your help.
SuperUser
Re: DHCP VLAN PROVISSIONING WITH THOMSON ST2030
Post by SuperUser »
Hi!
Have you ever tried make work option 43? With other models this option codify manufacture info.
I hope help you ;)
dryhouse
Post by dryhouse »
Yes, this option work in Iptouch terminals, but Thomson work with 190, 191 y 192 according with documentation.
Thanks for your reply.
Regards.
dryhouse
Post by dryhouse »
update the info...
Stuck.
DHCP send options with vlan info in the first DHCP Request. The terminal obtain IP of range data, mask, router, TFTP server, name of configuration files and the three options (190, 191 y 192).
Next, the terminal try TFTP with IP of data and Vlan tag MM...I do not understand very well. The terminal not send DHCP release....
The configuration of switches do not allow this traffic..
Return to “Outside World”
