4068 IP softphone
Elektra_K
4068 IP softphone
Post by Elektra_K »
we have a 4068 IP softphone for Win, version 11.0.11.1.
The phone was not responding, showing the message
"Set not registered", "Connection lost".
I followed the suggestions I found here
http://www.alcatelunleashed.com/viewtop ... 068#p38344
So I changed the "IP-Softphone Emulation" option in OXE to YES and worked fine!
But... Whenever a user logs out and another user logs in windows, the softphone is on the same state again ("Set not registered", "Connection lost").
What we need to do is to delete the Terminal Ethernet Address (i.e. the Mac address) from OXE so the next user can use the softphone again.
Is there a way to solve this problem, without having to manually removing Mac address every time?
Thank you,
Elektra
Re: 4068 IP softphone
Install it with ACD mode
You want to use ONE user from OXE (4068/ IP-Softphone Emulation) - for different users from different PC?
Create another user for next PC.
