CS-2 doesnt boot
bugsbunny3
CS-2 doesnt boot
Post by bugsbunny3 »
Hi all, I have problem with CS-2, after turn on I get inly this message :
Version 1.23.1109. Copyright (C) 2007 American Megatrends, Inc.
ALCATEL CS-2 BIOS VERSION 0ABPT110
Press ^B to enter setup.
Press ^I to boot EFI SHELL
Intel(R) Boot Agent GE v1.2.16P8
Copyright (C) 1997-2009, Intel Corporation
CLIENT MAC ADDR: 00 80 9F C0 BB 80 GUID: 00020003 0004 0005 0006 000700080009
CLIENT IP: 192.168.92.101 MASK: 255.255.255.0 DHCP IP: 192.168.92.100
GATEWAY IP: 192.168.92.100
I connected PC with PC installer, choice Instal Linux+call handling, Call handling version M1403, I see that CS-2 get IP address but nothig else happened.
It seems that there is no BIOS installed on CS-2. Can you help me?
Thank you.
Re: CS-2 doesnt boot
In PC Installer - you select CS-2 installation, not Alize?
bugsbunny3
Hi vad, you are right, I had choosen alize installation in PC installer, thank you for advice !!!
Return to “System”
