Ip Desktop Softphone and external TFTP
joaoj
Post by joaoj »
I have an external TFTP working with Ip touchs phones, and everything works fine. The phones download the lanpbx.cfg file and connect to the PABX to download the rest of the files.
But the IP Desktop softphone dont work like that.
The softphone download also the lanpbx.cfg file (but it seems that it dont care about the contents of that file), and after this, it will try to download the files bin4068-header, dat4068-header and startnoe-xxxxxxxxxxxx from the TFTP server, not from the pabx.
If i use the PABX ip address in the softphones, everythings works fine.
Is there some config in the softphones to resolve this issue?
Re: Ip Desktop Softphone and external TFTP
What are your tftp settings?
joaoj
Post by joaoj »
According to ALU, the softphone does not work with external TFTPs.
Return to “Ip Desktop Softphone”
