Can't remove port from vlan
hombrezuelo
Post by hombrezuelo »
Hi everyone
I'm facing issues with a port this is the scenario
This is the info:
@Alcatel-Lucent OS6850-P48L 6.4.3.609.R01
@Port 1/7 with vlan port mobile enable
@vlan port default 100
@vlans 100, 101, 102 and 103 are configured on the switch
When I enable vlan port mobile on port 1/7 in automatically the vlan 101 is added to port 1/7
Then I added vlan 102 on port 1/7 with the command vlan 102 port 1/7
Vlan 102 it's the correct one to be in that port, here is the result of command show vlan port 1/7
> show vlan port 1/7
vlan type status
100 default forwarding
101 mobile forwarding----------------------------------------this vlan I didn't add to the port.
102 mobile forwarding----------------------------------------this vlan I added manually
This is the way that I did to remove vlan 101 from port 1/7
-> vlan 101 no port 1/7
ERROR: Group Mobility - rule not present
And I'm not able to remove vlan 101 from port 1/7
is there something that I'm forgetting to do?
is there another way to remove that vlan?
Please someone can throw me a bone here?
Thank you for your time and consideration.
Re: Can't remove port from vlan
There must be a rule that your traffic is forwarded to vlan 101.
Check with show mac-address-table which client-mac is in this vlan.
Check your vlan rules with show vlan rules.
hombrezuelo
thanks for answering silvio this is the output of show vlan rules
-> show vlan rules
Legend: type: * = binding rule
type vlan rule
ip-net 100 192.168.100.0, 255.255.255.0
ip-net 101 192.168.101.0, 255.255.255.0
ip-net 102 192.168.102.0, 255.255.255.0
mac-range 3 00:80:9f:00:00:00, 00:80:9f:ff:ff:ff
port 3 1/1
port 5 1/1
port 5 1/3
port 5 1/23
port 5 1/28
port 2 1/29
port 5 1/29
port 5 1/34
port 2 2/2
port 5 2/5
port 5 2/18
port 3 2/29
port 4 2/29
port 5 2/35
port 3 3/10
port 4 3/10
port 4 3/16
port 5 3/25
port 3 3/29
port 3 3/31
port 5 3/34
port 3 3/38
port 4 3/38
port 6 3/44
port 4 4/1
port 2 4/4
port 4 4/4
port 3 4/8
port 4 4/8
port 3 4/25
port 3 4/26
port 4 4/26
port 5 4/29
port 2 4/32
port 5 4/32
port 4 4/45
port 4 4/46
and mac-address table I did a flush of client's mac address but still is getting the vlan 101
The rules says which ip-addresses and which mac-adresses are forwarded to vlan 100...102. And traffic from specific ports forwards to vlan 2...6.
You should check with wireshark the traffic at port 1/7. And have you checked show mac-adress-table 1/7? there you see the mac address in vlan 101. Is it the same like in 102?
