Fax over IP
Fax over IP
sip or h323...
regards...
regards...
dcwilliams
Re: Fax over IP
I have 5 fax machines that I need to connect. I guess it would be IP but it can be SIP if that works.
Re: Fax over IP
see the system doc
ip-pcx net /FaxRelay Over IP
ip-pcx net /Modem, fax and data transparency over IP
- tot3nkopf
Re: Fax over IP
Depends on FAX machine or madiation gw that you want to use: SIP extension, SIP trunk, H.323 trunk are the options.
