OTBE Services Are STOPPED
Some Services of OTBE are "STOPPED".
I tried to restart the Services by giving cmd: "service iced start (service name)".
But The Services Are Not Started.
Also an error is appearing "ALERT Partition full=> Remaining "/ 0%"".
Below Services Are Mentioned Which Are STOPPED:
>acs group > dbjournal (down)
>amsmediacontrol
>amsresourcemanager
>apache
>configproxy
>extensibleservices
>icsgroup
>messagebroker
>mule
>omp
>postgresqlacs
>postgresqlinfra
>sip server
Kindly help me out to restart the "SERVICES".
You can also mail me on "mobaid@procomme.com"
>amsmediacontrol
>amsresourcemanager
>apache
>configproxy
>extensibleservices
>icsgroup
>messagebroker
>mule
>omp
>postgresqlacs
>postgresqlinfra
>sip server
Re: OTBE Services Are STOPPED
this can have a lot of reasons.
Search for abnormal files in root partition using the command : du -ah --max-depth=1 | sort –n is one way to have an indication.
Can you specify the version of OTBE?
Br
rolfo
Br
rolfo
After giving the commmand : du -ah --max-depth=1 | sort -n
[otuser@opentouchbe ~]$
[otuser@opentouchbe ~]$ du -ah --max-depth=1 | sort -n
4.0K ./.bash_history
4.0K ./.bash_logout
4.0K ./.bash_profile
4.0K ./.bashrc
4.0K ./.emacs
4.0K ./.kshrc
4.0K ./.viminfo
12K ./.gnome2
12K ./.mozilla56K .
[otuser@opentouchbe ~]$ ^C
Broadcast message from root@opentouchbe.procomme.com (Thu Nov 17 16:20:01 2016):
ALERT Partitions FULL => REMAINING "/ : 0%"
The version of OTBE is "2.1.000.101"
Kindly let me know if anything is required.
Br,
Obaid
4.0K ./.bash_logout
4.0K ./.bashrc
4.0K ./.emacs
4.0K ./.kshrc
4.0K ./.viminfo
12K ./.gnome2
12K ./.mozilla56K .
Br,
Obaid
Try
du -a / --max-depth=1 | sort -nr | head -n 10
as well.
Mainly you need to find the spot in your server, which made it full.
as well.
After giving the command :du -a / --max-depth=1 | sort -nr | head -n 10
[root@opentouchbe otuser]# du -a / --max-depth=1 | sort -nr | head -n 10
du: cannot access `/proc/11625/task/11625/fd/17': No such file or directory
du: cannot access `/proc/54956/task/54956/fd/4': No such file or directory
du: cannot access `/proc/54956/task/54956/fdinfo/4': No such file or directory
du: cannot access `/proc/54956/fd/4': No such file or directory
du: cannot access `/proc/54956/fdinfo/4': No such file or directory
112673453 /
77599048 /mnt
23842612 /usr
5129776 /opt
4406009 /var
1307568 /logs
168908 /lib
74836 /home
41456 /boot
33144 /etc
Broadcast message from root@opentouchbe.procomme.com (Thu Nov 17 17:40:01 2016):
Br,
Obaid
112673453 /
77599048 /mnt
23842612 /usr
5129776 /opt
4406009 /var
1307568 /logs
168908 /lib
74836 /home
41456 /boot
33144 /etc
Br,
Obaid
sorry I am also just searching for good troubleshooting commands.
How about: df –h
Br
rolfo
How about: df –h
Br
rolfo
you can try:
find / -size +10000 -print|xargs ls -s|sort -rn
Hi Rolfo,
After giving the command: df -h
[root@opentouchbe otuser]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg_root_01-lv_root
30G 30G 0 100%
/tmpfs 9.8G 80K 9.8G 1% /dev/shm
/dev/sda1 485M 51M 409M 12% /boot
/dev/mapper/vg_root_01-lv_logs
20G 1.4G 18G 8% /logs
/dev/mapper/vg_common-lv_libvirt
104G 75G 24G 76% /mnt/virtualmachines
/dev/mapper/vg_common-lv_var_backup
100G 2.9G 92G 3% /var/backup
/dev/mapper/vg_root_01-lv_drbd1
20G 198M 19G 2% /var/data/ics-group
/dev/mapper/vg_root_01-lv_drbd4
155M 11M 137M 8% /var/data/moh
/dev/mapper/vg_root_01-lv_drbd3
9.9G 416M 9.0G 5% /var/data/oamp
/dev/mapper/vg_root_01-lv_ofs
7.9G 195M 7.3G 3% /var/data/ofs
/dev/mapper/vg_root_01-lv_postgresql
9.9G 301M 9.1G 4% /var/data/postgresql5432
/dev/mapper/vg_root_01-lv_drbd2
9.9G 308M 9.1G 4% /var/data/postgresql5433
/dev/mapper/vg_root_01-lv_slides
14G 200M 13G 2% /var/data/slides
Broadcast message from root@opentouchbe.procomme.com (Sun Nov 20 11:45:01 2016):
Br,
Obaid
30G 30G 0 100%
Br,
Obaid
Hi Sadim,
After giving command:
find: `/proc/34167/task/34167/fd/5': No such file or directory
find: `/proc/34167/task/34167/fdinfo/5': No such file or directory
find: `/proc/34167/fd/5': No such file or directory
find: `/proc/34167/fdinfo/5': No such file or directory
ls: cannot access /opt/ofs/Client/OpenTouch: No such file or directory
ls: cannot access Fax: No such file or directory
ls: cannot access Center: No such file or directory
ls: cannot access 7.5.2.98: No such file or directory
ls: cannot access (Client).exe: No such file or directory
52428808 /mnt/virtualmachines/images/vmManagement.img
20971524 /mnt/virtualmachines/images/vmOXE.img
4194308 /mnt/virtualmachines/images/vmOMS.img
801672 /var/backup/acs_tar/eiab6.tar.gz.rel_10_1_0b7506
448504 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/data/vf_tom_full_encrypt_f8.dat
352900 /opt/ofs/Bin/core.11413
328548 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/data/vf_emily_full_encrypt_f8.dat
273124 /var/backup/daily/host/20161001000109/opentouchbe.procomme.com.2016-10-01-00-01.zip
273108 /var/backup/daily/host/20160930000109/opentouchbe.procomme.com.2016-09-30-00-01.zip
273084 /var/backup/daily/host/20160929000109/opentouchbe.procomme.com.2016-09-29-00-01.zip
273056 /var/backup/daily/host/20160928000108/opentouchbe.procomme.com.2016-09-28-00-01.zip
273032 /var/backup/daily/host/20160927000109/opentouchbe.procomme.com.2016-09-27-00-01.zip
273008 /var/backup/daily/host/20160926000109/opentouchbe.procomme.com.2016-09-26-00-01.zip
272984 /var/backup/daily/host/20160925000109/opentouchbe.procomme.com.2016-09-25-00-01.zip
196256 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/data/vf_serena_full_encrypt_f8.dat
104432 /usr/share/icons/oxygen/icon-theme.cache
96796 /usr/lib/locale/locale-archive
87064 /opt/Alcatel-Lucent/voice_platform/AMS_ResourceManager/server/bin/resourcemgr
79348 /var/data/postgresql5432/base/16388/20926
76748 /opt/Alcatel-Lucent/sip_servers/SIPServer/sip_server_32
76748 /opt/Alcatel-Lucent/sip_servers/Mule/sip_server_32
69980 /opt/Alcatel-Lucent/opentouch_conversation_update/opentouch_conversation_update/OpenTouchConversation.msi
66108 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libCMSIP2.so
62420 /opt/Alcatel-Lucent/opentouch_connection_update/opentouch_connection_update/OpenTouchConnectionX64.msi
62420 /opt/Alcatel-Lucent/opentouch_connection_update/opentouch_connection_update/OpenTouchConnection-x64.msi
61656 /opt/Alcatel-Lucent/opentouch_connection_update/opentouch_connection_update/OpenTouchConnection.msi
61228 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/EMSDataCollection.so
60912 /opt/Alcatel-Lucent/platform/jdk/jre/lib/rt.jar
60776 /var/lib/rpm/Packages
55660 /usr/lib64/libwireshark.so.2.0.10
54612 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libCMNGMS.so
53528 /usr/vmware/dcs_vmware-6.zip
52848 /usr/java/jre1.7.0_80/lib/rt.jar
51816 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libAPPVXML3.so
51200 /opt/Alcatel-Lucent/sip_servers/SIPServer/SIPServer.dyn
51200 /opt/Alcatel-Lucent/sip_servers/SIPServer/SIPServer.cfg
51200 /opt/Alcatel-Lucent/sip_servers/Mule/Mule.dyn
51200 /opt/Alcatel-Lucent/sip_servers/Mule/Mule.cfg
45296 /opt/Alcatel-Lucent/jre/lib/rt.jar
43728 /usr/sbin/mysqld
41476 /usr/sbin/mysqld-debug
37452 /opt/ofs/Bin/faxreports.war
36352 /opt/Alcatel-Lucent/jre/linux_abs.bin
36080 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/pwcallmgr
35648 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libavcodec.so.54
35136 /usr/lib64/xulrunner/libxul.so
35028 /usr/promptsets/zips/promptset_ZHO-CN.zip
34540 /opt/ofs/_jvm/lib/rt.jar
33784 /opt/ofs/Bin/XMConfigManager
33536 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.9.677-signed/rpms/QT-5.3.1-R100_01.008.2.660_8088.armv7a_vfp_neon.rpm
33536 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.7.672-signed/rpms/QT-5.3.1-R100_01.008.2.660_8088.armv7a_vfp_neon.rpm
32780 /opt/ofs/Upgrade/libCppImport.so
32780 /opt/ofs/Bin/libCppImport.so
32044 /var/lib/mlocate/mlocate.db
31404 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/data/us_tom_full_encrypt.dat
29924 /usr/soapadmin/ACSAdmin.war
29924 /opt/Alcatel-Lucent/acs_webapps/soapadmin/1_0/ACSAdmin.war
29184 /opt/ofs/Bin/XMFaxManager
28596 /usr/local/apache/htdocs/content/ZHO-CN/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/SWE-SE/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/SPA-ES/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/RUS-RU/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/POR-PT/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/POL-PL/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/NOR-NO/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/NLD-NL/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/KOR-KN/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/JPN-JP/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/ITA-IT/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/HUN-HU/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/FRE-FR/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/FIN-FI/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/ENG-US/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/DEU-DE/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/DAN-DA/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/CZE-CZ/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/CHT-TW/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/CAT-CA/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/ARA-KW/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/content/0/htdocs/buddies/templates/components/MyInstantCommunicator.msi
28596 /usr/local/apache/htdocs/components/MyInstantCommunicator.msi
28596 /usr/buddyconsole/htdocs/buddies/components/MyInstantCommunicator.msi
26744 /opt/ofs/Bin/XMFaxDriver
26624 /var/data/ofs/mysqldata/ibdata1
26512 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libmrcpv2client.so
26240 /opt/ofs/Bin/XMFaxDriver-Legacy
25092 /opt/ofs/Bin/XMSmtpGateway
24372 /opt/ofs/Bin/XMXmlGateway
24348 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libmrcpv1client.so
23368 /opt/Alcatel-Lucent/infra_services/acapi/_jvm14/lib/rt.jar
23068 /usr/java/jre1.7.0_80/lib/i386/libjfxwebkit.so
23064 /opt/Alcatel-Lucent/platform/jdk/jre/lib/i386/libjfxwebkit.so
22256 /opt/Alcatel-Lucent/infra_services/connector2007/system/com/alcatel_lucent/ice/ics/exchange_2007_connector_server/connector2007server/2.0.500.063/connector2007server-2.0.500.063.jar
22256 /opt/Alcatel-Lucent/infra_services/connector2007/data/cache/bundle190/version0.0/bundle.jar
22256 /home/htuser/.m2/repository/com/alcatel_lucent/ice/ics/exchange_2007_connector_server/connector2007server/2.0.500.063/connector2007server-2.0.500.063.jar
21912 /opt/ofs/Bin/Raster/lib/libvs_acad.so
21796 /opt/ofs/Bin/XMProxy
21524 /opt/ofs/Bin/Raster/bin/gs
21116 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libxerces-c-3.1.so
20668 /opt/ofs/Bin/XMDocumentRasterizer
20356 /opt/ofs/Bin/XMFaultTolerance
19512 /logs/ofs/Smtp.log
19084 /logs/ofs/FaultTolerance.log
18872 /opt/ofs/Bin/faxservice.war
18524 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/data/us_emily_full_encrypt.dat
17928 /opt/ofs/Bin/Util/xmdc
17852 /opt/ofs/Upgrade/libicudata.so.48.1.1
17852 /opt/ofs/Bin/libicudata.so.48.1.1
17580 /opt/ofs/Bin/faxuser.war
17544 /usr/promptsets/zips/promptset_ARA-KW.zip
17040 /boot/initrd-2.6.32-431.el6.x86_64.part1.img
17040 /boot/initramfs-2.6.32-431.el6.x86_64.img
16988 /usr/lib/libLLVM-3.3-mesa.so
16428 /usr/lib64/libLLVM-3.3-mesa.so
16384 /var/data/postgresql5433/pg_xlog/0000000100000008000000A5
16384 /var/data/postgresql5432/pg_xlog/0000000100000002000000E4
16364 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/data/us_serena_full_encrypt.dat
16152 /opt/Alcatel-Lucent/platform/jdk/lib/ct.sym
16132 /usr/server/acs-ice/perl64modules.tar
16132 /usr/server/acs-64bit/perl64modules.tar
15496 /opt/ofs/Bin/faxhelp.war
15480 /usr/linux-doc-conversion/ghostscript-9.06-linux_x86_64.tar
15476 /usr/linux-doc-conversion/ghostscript-9.06-linux_x86_64/gs
15148 /logs/ofs/ConfigManager.Log
14868 /opt/Alcatel-Lucent/platform/jdk/lib/tools.jar
14840 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libicudata.so.46
14792 /opt/Alcatel-Lucent/platform/jdk/jre/lib/jfxrt.jar
14680 /usr/promptsets/zips/promptset_CZE-CZ.zip
14664 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libmrcpdtmfclient.so
14660 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.9.677-signed/rpms/webapp_screensaver-20.0.13-R100_01.008.8.675_8088.noarch.rpm
14660 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.7.672-signed/rpms/webapp_screensaver-20.0.13-R100_01.008.7.671_8088.noarch.rpm
14632 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libAPPMSML.so
14536 /var/spool/up2date/glibc-common-2.12-1.149.el6_6.7.x86_64.rpm
14536 /usr/eiab/rpm-standalone/glibc-common-2.12-1.149.el6_6.7.x86_64.rpm
14524 /usr/eiab/rpm-standalone/glibc-common-2.12-1.149.el6_6.7.i686.rpm
14480 /var/tmp/acs_restart.log
14416 /usr/java/jre1.7.0_80/lib/i386/client/classes.jsa
13932 /usr/promptsets/zips/promptset_CAT-CA.zip
13924 /opt/Alcatel-Lucent/jre/lib/i386/client/classes.jsa
13820 /usr/promptsets/zips/promptset_POL-PL.zip
13720 /usr/promptsets/zips/promptset_HUN-HU.zip
13644 /usr/promptsets/zips/promptset_POR-PT.zip
13560 /logs/chameleon/localhost.access.Monday.log
13512 /logs/chameleon/localhost.access.Sunday.log
13476 /logs/ofs/FaxManager.log
13440 /usr/promptsets/zips/promptset_RUS-RU.zip
13404 /logs/ofs/DocumentRasterizer.log
13364 /logs/chameleon/localhost.access.Thursday.log
13328 /logs/flexlm/flexlm_lmlog.log
13300 /opt/ofs/Bin/faxadminhelp.war
13248 /usr/java/jre1.7.0_80/lib/jfxrt.jar
13156 /usr/promptsets/zips/promptset_ITA-IT.zip
13144 /opt/Alcatel-Lucent/voip_plugin_update/voip_plugin_update/VoipPlugin.msi
13120 /logs/chameleon/localhost.access.Wednesday.log
13100 /logs/chameleon/localhost.access.Tuesday.log
12768 /usr/promptsets/zips/promptset_JPN-JP.zip
12692 /usr/promptsets/zips/promptset_FRE-FR.zip
12600 /usr/promptsets/zips/promptset_FIN-FI.zip
12564 /usr/promptsets/zips/promptset_SPA-ES.zip
12432 /usr/promptsets/zips/promptset_NLD-NL.zip
12400 /usr/vmware/ImageMagick-6.7.2-Q16/ffmpeg.exe
12292 /opt/ofs/Bin/XMSnmpAgent
12288 /usr/promptsets/zips/promptset_NOR-NO.zip
12284 /logs/chameleon/localhost.access.Friday.log
12192 /logs/chameleon/localhost.access.Saturday.log
12136 /usr/promptsets/zips/promptset_DEU-DE.zip
12132 /opt/ofs/Upgrade/XMUpgrader
11916 /opt/ofs/_jvm/lib/i386/client/classes.jsa
11896 /opt/ofs/Bin/Util/FirstTimeSetup
11780 /opt/apache-tomcat-7.0.61/webapps/faxreports/WEB-INF/lib/org.eclipse.birt.runtime_3.7.1.v20110913-1734.jar
11400 /opt/apache-tomcat-7.0.61/webapps/faxuser/WEB-INF/lib/webservices-rt.jar
11400 /opt/apache-tomcat-7.0.61/webapps/faxservice/WEB-INF/lib/webservices-rt.jar
11316 /usr/java/jre1.7.0_80/lib/i386/server/libjvm.so
11240 /opt/Alcatel-Lucent/platform/jdk/jre/lib/i386/server/libjvm.so
11196 /usr/promptsets/zips/promptset_ZHO-HK.zip
10888 /usr/bin/emacs-23.1
10872 /usr/bin/umbrello
10836 /usr/eiab/bin/convert
10784 /usr/vmware/gs/gs8.64/bin/gsdll32.dll
10784 /usr/vmware/GSDLL32.dll
10748 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libavformat.so.54
10456 /opt/ofs/Bin/core.28781
10392 /usr/lib64/libQtGui.so.4.6.2
10376 /usr/lib/libQtGui.so.4.6.2
10304 /logs/ConfigProxy/configProxy.9.log
10264 /logs/ofs/XmlGateway.log
10264 /logs/ConfigProxy/configProxy.2.log
10260 /logs/ConfigProxy/configProxy.8.log
10260 /logs/ConfigProxy/configProxy.13.log
10256 /logs/ConfigProxy/configProxy.3.log
10248 /logs/ConfigProxy/configProxy.7.log
10248 /logs/ConfigProxy/configProxy.6.log
10248 /logs/ConfigProxy/configProxy.5.log
10248 /logs/ConfigProxy/configProxy.4.log
10248 /logs/ConfigProxy/configProxy.1.log
10248 /logs/ConfigProxy/configProxy.12.log
10248 /logs/ConfigProxy/configProxy.11.log
10248 /logs/ConfigProxy/configProxy.10.log
10240 /var/data/ics-group/acapi/data/openldap/log.0000002159
10228 /usr/newupg/cgi-bin/vcs_contacts
10228 /usr/local/apache/cgi-bin/vcs_contacts
10136 /usr/newupg/cgi-bin/vcs_replay
10136 /usr/local/apache/cgi-bin/vcs_replay
10084 /usr/newupg/cgi-bin/vcs_call
10084 /usr/local/apache/cgi-bin/vcs_call
10072 /opt/ofs/Bin/OpenDS.jar
10064 /usr/newupg/cgi-bin/vcs_recording
10064 /usr/local/apache/cgi-bin/vcs_recording
10052 /usr/newupg/cgi-bin/conference1
10052 /usr/local/apache/cgi-bin/conference1
10032 /usr/newupg/cgi-bin/vcs_conf_schedule
10032 /usr/local/apache/cgi-bin/vcs_conf_schedule
10028 /usr/newupg/cgi-bin/vcs_user_settings
10028 /usr/local/apache/cgi-bin/vcs_user_settings
10024 /usr/newupg/cgi-bin/buddies_attach
10024 /usr/local/apache/cgi-bin/buddies_attach
9996 /usr/newupg/cgi-bin/ivr_join
9996 /usr/local/apache/cgi-bin/ivr_join
9976 /usr/newupg/cgi-bin/ivr_recording
9976 /usr/local/apache/cgi-bin/ivr_recording
9956 /usr/newupg/cgi-bin/conference
9956 /usr/local/apache/cgi-bin/conference
9952 /usr/newupg/cgi-bin/vcs_slideshow
9952 /usr/local/apache/cgi-bin/vcs_slideshow
9948 /usr/newupg/cgi-bin/web_join
9948 /usr/newupg/cgi-bin/vcs_beacon
9948 /usr/local/apache/cgi-bin/web_join
9948 /usr/local/apache/cgi-bin/vcs_beacon
9940 /usr/newupg/cgi-bin/buddies_playback
9940 /usr/local/apache/cgi-bin/buddies_playback
9936 /usr/newupg/cgi-bin/vcs_delete_documents
9936 /usr/local/apache/cgi-bin/vcs_delete_documents
9928 /usr/newupg/cgi-bin/vcs_conf_delete
9928 /usr/local/apache/cgi-bin/vcs_conf_delete
9924 /usr/newupg/cgi-bin/notify_owner
9924 /usr/local/apache/cgi-bin/notify_owner
9916 /usr/newupg/cgi-bin/rollcall
9916 /usr/newupg/cgi-bin/ivr_controls
9916 /usr/newupg/cgi-bin/buddies_conf_schedule
9916 /usr/local/apache/cgi-bin/rollcall
9916 /usr/local/apache/cgi-bin/ivr_controls
9916 /usr/local/apache/cgi-bin/buddies_conf_schedule
9912 /usr/newupg/cgi-bin/vcs_set_delegate
9912 /usr/newupg/cgi-bin/vcs_register_number
9912 /usr/newupg/cgi-bin/vcs_document_password
9912 /usr/newupg/cgi-bin/vcs_delete_delegate
9912 /usr/newupg/cgi-bin/vcs_chgpwd
9912 /usr/local/apache/cgi-bin/vcs_set_delegate
9912 /usr/local/apache/cgi-bin/vcs_register_number
9912 /usr/local/apache/cgi-bin/vcs_document_password
9912 /usr/local/apache/cgi-bin/vcs_delete_delegate
9912 /usr/local/apache/cgi-bin/vcs_chgpwd
9908 /usr/newupg/cgi-bin/vcs_signout
9908 /usr/newupg/cgi-bin/vcs_signin
9908 /usr/newupg/cgi-bin/vcs_ldap_signin
9908 /usr/newupg/cgi-bin/vcs_ivr_signin
9908 /usr/local/apache/cgi-bin/vcs_signout
9908 /usr/local/apache/cgi-bin/vcs_signin
9908 /usr/local/apache/cgi-bin/vcs_ldap_signin
9908 /usr/local/apache/cgi-bin/vcs_ivr_signin
9904 /usr/newupg/cgi-bin/vcs_test_email
9904 /usr/local/apache/cgi-bin/vcs_test_email
9892 /usr/newupg/cgi-bin/recCallid
9892 /usr/newupg/cgi-bin/legAction
9892 /usr/local/apache/cgi-bin/recCallid
9892 /usr/local/apache/cgi-bin/legAction
9884 /usr/newupg/cgi-bin/buddies_download
9884 /usr/local/apache/cgi-bin/buddies_download
9880 /usr/newupg/get_user_disk_usage
9880 /usr/newupg/cgi-bin/get_user_disk_usage
9880 /usr/local/apache/cgi-bin/get_user_disk_usage
9856 /usr/newupg/ldap_test
9856 /usr/newupg/ldap_sync
9852 /usr/sbin/smbd
9852 /usr/newupg/cgi-bin/otuc_authenticate
9852 /usr/newupg/cgi-bin/otuc_admin_authenticate
9852 /usr/newupg/cgi-bin/ldap_cgi
9852 /usr/local/apache/cgi-bin/otuc_authenticate
9852 /usr/local/apache/cgi-bin/otuc_admin_authenticate
9852 /usr/local/apache/cgi-bin/ldap_cgi
9132 /usr/libexec/gcc/x86_64-redhat-linux/4.4.4/cc1
8988 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.9.677-signed/rpms/libicudata52-51.2-R100_01.005.0.560_8088.armv7a_vfp_neon.rpm
8988 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.7.672-signed/rpms/libicudata52-51.2-R100_01.005.0.560_8088.armv7a_vfp_neon.rpm
8968 /opt/Alcatel-Lucent/jre/lib/i386/server/libjvm.so
8888 /usr/lib64/qt-3.3/lib/libqt-mt.so.3.3.8
8852 /usr/eiab/bin/animate
8852 /logs/ConfigProxy/configProxy.log
8804 /usr/eiab/bin/compare
8796 /usr/eiab/bin/display
8792 /usr/eiab/bin/montage
8784 /usr/eiab/bin/composite
8772 /usr/eiab/bin/import
8764 /opt/ofs/Bin/Raster/lib/oit_font_metrics.db
8736 /usr/eiab/bin/stream
8736 /usr/eiab/bin/identify
8716 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/common/libicudata.so.22
8700 /usr/eiab/bin/conjure
8684 /usr/eiab/bin/mogrify
8652 /var/spool/abrt/ccpp-2016-04-06-00:02:28-20135/coredump
8652 /opt/ofs/Bin/core.20135
8488 /usr/bin/net
8420 /usr/share/cracklib/pw_dict.pwd
8312 /opt/ofs/_jvm/lib/charsets.jar
8256 /usr/lib/qt-3.3/lib/libqt-mt.so.3.3.8
8236 /opt/Alcatel-Lucent/infra_services/connector2007/system/com/alcatel_lucent/ice/ics/osgi/opentouch/legacy/legacy-cmsclient-core/2.0.500.050.b0161/legacy-cmsclient-core-2.0.500.050.b0161.jar
8236 /opt/Alcatel-Lucent/infra_services/connector2007/data/cache/bundle157/version0.0/bundle.jar
8236 /home/htuser/.m2/repository/com/alcatel_lucent/ice/ics/osgi/opentouch/legacy/legacy-cmsclient-core/2.0.500.050.b0161/legacy-cmsclient-core-2.0.500.050.b0161.jar
8188 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/common/icudt22l.dat
8160 /opt/Alcatel-Lucent/acs_webapps/soapadmin/1_0/WEB-INF/lib/eclipselink.jar
8080 /var/lib/rpm/Filedigests
8056 /usr/tns/tp260dvr
8024 /usr/local/Nuance/SpeechServer_5/server/lib/libSRicudata.so.21
8008 /opt/Alcatel-Lucent/otc_srv/otweb/img/color_wheel/gfx_brushsize.psd
7684 /usr/sbin/winbindd
7636 /var/data/postgresql5432/base/16388/20929
7612 /opt/Alcatel-Lucent/opentouch_conversation_sharing/otcsharing/OTCSharing.msi
7544 /usr/bin/rpcclient
7480 /opt/Alcatel-Lucent/infra_services/acapi/_jvm14/lib/i386/server/libjvm.so
7320 /usr/bin/mysql
7204 /usr/java/jre1.7.0_80/lib/i386/client/libjvm.so
7132 /opt/Alcatel-Lucent/platform/jdk/jre/lib/i386/client/libjvm.so
7124 /usr/bin/mysqltest
7124 /etc/selinux/targeted/policy/policy.24
7124 /etc/selinux/targeted/modules/active/policy.kern
7116 /usr/lib64/libkhtml.so.5.3.0
7068 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/common/libxml4c.so.50
7060 /usr/bin/mysqlbinlog
7024 /usr/lib64/libQtDesigner.so.4.6.2
7012 /usr/local/Nuance/SpeechServer_5/server/lib/libosrspeechrecog.so
6996 /var/data/postgresql5432/base/16388/17624
6980 /usr/share/icons/gnome/icon-theme.cache
6880 /usr/promptsets/zips/promptset_FRE-CA.zip
6864 /usr/lib/libQtDesigner.so.4.6.2
6824 /usr/lib/libgs.so.8.70
6800 /usr/bin/mysqldump
6768 /opt/ofs/_jvm/lib/i386/server/libjvm.so
6760 /opt/Alcatel-Lucent/voice_platform/AMS_MediaControl/server/bin/libAPPNetann.so
6612 /usr/bin/mysqlslap
6608 /usr/promptsets/zips/promptset_KOR-KR.zip
6584 /usr/lib64/libnetapi.so.0
6560 /usr/bin/mysqlimport
6560 /usr/bin/mysqladmin
6556 /opt/Alcatel-Lucent/jre/lib/charsets.jar
6552 /usr/bin/mysqlcheck
6548 /opt/Alcatel-Lucent/platform/jdk/lib/missioncontrol/plugins/com.ibm.icu_4.4.2.v20110823.jar
6544 /usr/bin/mysqlshow
6536 /opt/apache-tomcat-7.0.61/webapps/faxreports/WEB-INF/lib/com.ibm.icu_4.4.2.v20110208.jar
6484 /usr/local/Nuance/SpeechServer_5/server/lib/librsspeechsynth.so
6404 /usr/lib64/dri/r600_dri.so
6388 /usr/promptsets/zips/promptset_SWE-SE.zip
6360 /usr/local/ScanSoft/RealSpeak_4.0/speech/components/common/libACE.so.5.3.0
6312 /var/data/postgresql5432/base/16388/17627
6292 /usr/bin/smbget
6248 /usr/local/Nuance/SpeechServer_5/server/lib/librecorder.so
6236 /usr/lib/dri/r600_dri.so
6236 /opt/ofs/Bin/jacorb.jar
6152 /var/log/audit/audit.log.4
6152 /var/log/audit/audit.log.3
6152 /var/log/audit/audit.log.2
6152 /var/log/audit/audit.log.1
6100 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.9.677-signed/rpms/media-100.0-R100_01.008.9.677_8088.armv7a_vfp_neon.rpm
6100 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.7.672-signed/rpms/media-100.0-R100_01.008.7.672_8088.armv7a_vfp_neon.rpm
6096 /usr/bin/smbclient
6076 /usr/bin/smbpasswd
6064 /usr/promptsets/zips/promptset_DAN-DA.zip
6060 /usr/bin/smbcacls
6052 /usr/bin/smbcquotas
6052 /logs/ofs/FaxArchive.log
6036 /usr/tns/images/TP260_UN_F5.20.035.001.cmp
6036 /tftpboot/images/TP260_UN_F5.20.035.001.cmp
6024 /opt/Alcatel-Lucent/infra_services/shrew/lib/log4cxx/lib/liblog4cxx.so.9
6024 /opt/Alcatel-Lucent/infra_services/ots/lib/log4cxx/lib/liblog4cxx.so.9
6004 /var/data/postgresql5433/base/16408/20627
5992 /usr/bin/smbtree
5876 /usr/lib64/libsmbclient.so.0
5832 /usr/bin/myisamchk
5800 /usr/promptsets/zips/promptset_NLD-BE.zip
5772 /usr/lib64/dri/r300_dri.so
5732 /usr/lib/dri/r300_dri.so
5720 /opt/Alcatel-Lucent/jre/lib/i386/client/libjvm.so
5708 /usr/acs2cms/lib/cms/cmsclient-processor-3.2.100.601-jar-with-dependencies.jar
5668 /logs/ofs/Proxy.log
5644 /usr/local/Nuance/SpeechServer_5/server/lib/libmrcp1core.so
5592 /usr/lib64/dri/radeonsi_dri.so
5592 /opt/Alcatel-Lucent/infra_services/connector2007/system/org/apache/servicemix/bundles/org.apache.servicemix.bundles.opensaml/2.5.3_3/org.apache.servicemix.bundles.opensaml-2.5.3_3.jar
5552 /usr/promptsets/zips/promptset_ENG-GB.zip
5548 /usr/lib/dri/radeonsi_dri.so
5532 /usr/bin/myisampack
5444 /usr/bin/myisam_ftdump
5432 /usr/bin/myisamlog
5408 /opt/Alcatel-Lucent/infra_services/acapi/_jvm14/lib/charsets.jar
5404 /var/spool/abrt/ccpp-2016-04-06-00:02:28-20135/sosreport.tar.xz
5360 /usr/promptsets/zips/promptset_ENG-US.zip
5356 /usr/local/Nuance/SpeechServer_5/server/lib/librtpstack.so
5316 /usr/local/Nuance/SpeechServer_5/server/bin/NSSserver
5260 /usr/local/Nuance/SpeechServer_5/server/lib/libmrcpinet.so
5232 /var/backup/on_demand/opentouchbe.deploy.ale.2016-02-18-11-00.zip
5232 /usr/alc/firstBackup.zip
5224 /usr/local/Nuance/SpeechServer_5/server/lib/libnuancecoreservices.so
5204 /usr/promptsets/zips/promptset_TUR-TR.zip
5204 /usr/lib64/atlas/liblapack.so.3.0
5192 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.9.677-signed/rpms/kernel-image-3.4.43-wr5.0.1.8-standard-3.4-R100_01.008.9.677_8088.fsl_imx6.rpm
5188 /var/data/oamp/cms/DevicesDeployment/fwictouch/8088-R100.01.008.7.672-signed/rpms/kernel-image-3.4.43-wr5.0.1.8-standard-3.4-R100_01.008.7.672_8088.fsl_imx6.rpm
5184 /var/log/maillog-20161106
5176 /var/log/maillog-20161120
5172 /opt/ofs/Bin/faxadmin.war
5168 /usr/local/apache/htdocs/content/ZHO-CN/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/SWE-SE/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/SPA-ES/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/RUS-RU/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/POR-PT/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/POL-PL/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/NOR-NO/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/NLD-NL/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/KOR-KN/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/JPN-JP/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/ITA-IT/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/HUN-HU/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/FRE-FR/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/FIN-FI/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/ENG-US/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/DEU-DE/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/DAN-DA/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/CZE-CZ/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/CHT-TW/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/CAT-CA/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/ARA-KW/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/content/0/htdocs/buddies/templates/components/MSComponentSetup.msi
5168 /usr/local/apache/htdocs/components/MSComponentSetup.msi
5168 /usr/buddyconsole/htdocs/buddies/components/MSComponentSetup.msi
5156 /var/log/maillog-20161113
5148 /logs/udas/udas_standard_mode_traces.log.9
5148 /logs/udas/udas_standard_mode_traces.log.10
5144 /logs/udas/udas_standard_mode_traces.log.8
5144 /logs/tomcat/ACSAdmin/traces.log.4
5144 /logs/tomcat/ACSAdmin/traces.log.2
5136 /logs/appguard/errors.1.log
5132 /logs/chameleon/alcatel.log.6
5132 /logs/chameleon/alcatel.log.10
5132 /logs/appguard/errors.5.log
5132 /logs/appguard/errors.4.log
5128 /logs/udas/udas_standard_mode_traces.log.7
5128 /logs/udas/udas_standard_mode_traces.log.6
5128 /logs/udas/udas_standard_mode_traces.log.5
5128 /logs/udas/udas_standard_mode_traces.log.4
5128 /logs/udas/udas_standard_mode_traces.log.3
5128 /logs/udas/udas_standard_mode_traces.log.2
5128 /logs/udas/udas_standard_mode_traces.log.1
5128 /logs/tomcat/ACSAdmin/traces.log.8
5128 /logs/tomcat/ACSAdmin/traces.log.7
5128 /logs/tomcat/ACSAdmin/traces.log.6
5128 /logs/tomcat/ACSAdmin/traces.log.5
5128 /logs/tomcat/ACSAdmin/traces.log.3
5128 /logs/tomcat/ACSAdmin/traces.log.1
5128 /logs/shrew/shrew_traces.log.9
5128 /logs/shrew/shrew_traces.log.8
5128 /logs/shrew/shrew_traces.log.7
5128 /logs/shrew/shrew_traces.log.6
5128 /logs/shrew/shrew_traces.log.5
5128 /logs/shrew/shrew_traces.log.4
5128 /logs/shrew/shrew_traces.log.3
5128 /logs/shrew/shrew_traces.log.2
5128 /logs/shrew/shrew_traces.log.10
5128 /logs/pms/pms_traces.log.3
5128 /logs/pms/pms_traces.log.2
5128 /logs/pms/pms_traces.log.1
5128 /logs/ots/ots_traces.log.3
5128 /logs/ots/ots_traces.log.2
5128 /logs/ots/ots_traces.log.1
5128 /logs/journal/martin.log.5
5128 /logs/journal/martin.log.4
5128 /logs/journal/martin.log.3
5128 /logs/journal/martin.log.2
5128 /logs/journal/martin.log.1
5128 /logs/journal/chameleon.log.9
5128 /logs/journal/chameleon.log.8
5128 /logs/journal/chameleon.log.7
5128 /logs/journal/chameleon.log.6
5128 /logs/journal/chameleon.log.5
5128 /logs/journal/chameleon.log.3
5128 /logs/journal/chameleon.log.2
5128 /logs/journal/chameleon.log.10
5128 /logs/connector2007/_opentouch.log.9
5128 /logs/connector2007/_opentouch.log.8
5128 /logs/connector2007/_opentouch.log.7
5128 /logs/connector2007/_opentouch.log.6
5128 /logs/connector2007/_opentouch.log.5
5128 /logs/connector2007/_opentouch.log.4
5128 /logs/connector2007/_opentouch.log.3
5128 /logs/connector2007/_opentouch.log.2
5128 /logs/connector2007/_opentouch.log.10
5128 /logs/connector2007/connector2007_statistic.log.1
5128 /logs/connector2007/com.alcatel_lucent.ice.ics.osgi.opentouch.opentouch-framework-core.log.4
5128 /logs/connector2007/com.alcatel_lucent.ice.ics.osgi.opentouch.opentouch-framework-core.log.3
5128 /logs/connector2007/com.alcatel_lucent.ice.ics.osgi.opentouch.opentouch-framework-core.log.2
5128 /logs/connector2007/com.alcatel_lucent.ice.ics.osgi.opentouch.opentouch-framework-core.log.1
5128 /logs/cms/cms_traces.log.5
5128 /logs/cms/cms_traces.log.4
5128 /logs/cms/cms_traces.log.3
5128 /logs/cms/cms_traces.log.2
5128 /logs/cms/cms_traces.log.1
5128 /logs/chameleon/chameleon/ims.log.1
5128 /logs/chameleon/chameleon/csta-psdk.log.9
5128 /logs/chameleon/chameleon/csta-psdk.log.8
5128 /logs/chameleon/chameleon/csta-psdk.log.7
5128 /logs/chameleon/chameleon/csta-psdk.log.6
5128 /logs/chameleon/chameleon/csta-psdk.log.5
5128 /logs/chameleon/chameleon/csta-psdk.log.4
5128 /logs/chameleon/chameleon/csta-psdk.log.3
5128 /logs/chameleon/chameleon/csta-psdk.log.2
5128 /logs/chameleon/chameleon/csta-psdk.log.10
5128 /logs/chameleon/chameleon/chameleon.log.9
5128 /logs/chameleon/chameleon/chameleon.log.8
5128 /logs/chameleon/chameleon/chameleon.log.7
5128 /logs/chameleon/chameleon/chameleon.log.6
5128 /logs/chameleon/chameleon/chameleon.log.5
5128 /logs/chameleon/chameleon/chameleon.log.4
5128 /logs/chameleon/chameleon/chameleon.log.3
5128 /logs/chameleon/chameleon/chameleon.log.2
5128 /logs/chameleon/chameleon/chameleon.log.1
5128 /logs/chameleon/chameleon/cache.log.1
5128 /logs/chameleon/alcatel.log.9
5128 /logs/chameleon/alcatel.log.8
5128 /logs/chameleon/alcatel.log.7
5128 /logs/chameleon/alcatel.log.5
5128 /logs/chameleon/alcatel.log.4
5128 /logs/chameleon/alcatel.log.3
5128 /logs/chameleon/alcatel.log.2
5128 /logs/chameleon/alcatel.log.1
5128 /logs/backup/backup_traces.log.1
5128 /logs/appguard/traces.5.log
5128 /logs/appguard/traces.4.log
5128 /logs/appguard/traces.3.log
5128 /logs/appguard/traces.2.log
5128 /logs/appguard/traces.1.log
5128 /logs/appguard/errors.3.log
5128 /logs/appguard/errors.2.log
5128 /logs/acapi/NMCGCSAdmin_1.log
5128 /logs/acapi/NMCComServer_1.log
5128 /logs/acapi/NMCCMISD_1.log
5128 /logs/acapi/NMCA4400alarmRcvr_1.log
5124 /logs/journal/chameleon.log.4
5124 /logs/chameleon/chameleon/chameleon.log.10
5120 /var/data/ofs/mysqldata/ib_logfile1
5120 /var/data/ofs/mysqldata/ib_logfile0
5084 /var/spool/abrt/ccpp-2016-03-03-00:02:36-20189/coredump
5084 /var/data/postgresql5433/base/16408/20581
5084 /opt/ofs/Bin/core.20189
5076 /usr/share/icons/hicolor/icon-theme.cache
5060 /usr/lib/libxalan-c.so.110.0
5060 /opt/Alcatel-Lucent/infra_services/ots/main_tsa
5048 /usr/local/apache/htdocs/content/ZHO-CN/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/SWE-SE/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/SPA-ES/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/RUS-RU/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/POR-PT/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/POL-PL/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/NOR-NO/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/NLD-NL/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/KOR-KN/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/JPN-JP/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/ITA-IT/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/HUN-HU/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/FRE-FR/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/FIN-FI/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/ENG-US/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/DEU-DE/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/DAN-DA/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/CZE-CZ/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/CHT-TW/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/CAT-CA/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/ARA-KW/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/content/0/htdocs/buddies/templates/components/MSComponentSetup.exe
5048 /usr/local/apache/htdocs/components/MSComponentSetup.exe
5048 /usr/buddyconsole/htdocs/buddies/components/MSComponentSetup.exe
5040 /opt/Alcatel-Lucent/infra_services/acapi/_jvm14/lib/i386/client/libjvm.so
5008 /logs/ecs/ecs_traces.log.9
5008 /logs/ecs/ecs_traces.log.8
5008 /logs/ecs/ecs_traces.log.7
5008 /logs/ecs/ecs_traces.log.6
5008 /logs/ecs/ecs_traces.log.5
5008 /logs/ecs/ecs_traces.log.4
5008 /logs/ecs/ecs_traces.log.3
5008 /logs/ecs/ecs_traces.log.2
5008 /logs/ecs/ecs_traces.log.10
4636 /var/data/ics-group/acapi/data/openldap/log.0000002160
4412 /var/lib/rpm/Basenames
224 dialog
160 dir_protect.so
112 HASPserno
104 pcitable
104 nightly-cleanup
68 /dev/shm/pulse-shm-2813870981
44 eiab.conf
44 at-3.1.8-20.i386.rpm
36 /var/tmp/kdecache-root/kpc/kde-icon-cache.data
28 set_system_options.pl
28 cmsxml2conf.pl
24 edialinitial
20 xte
20 set_stacking.pl
16 rc.sysinit
16 mime.types
12 vmfunctions
12 set_video_settings.pl
12 postinstall.bin.sh
12 openser.cfg
12 kamailio.cfg
12 functions
12 compresslogs
12 cms2acs.xml
12 acsLcaProxy
8 upgradeconf.sh
8 set_logging_levels.pl
8 set_accesscodes.pl
8 serverstatus.sh
8 sendmailWatchDogd
8 revertbox.sh
8 process_args.sh
8 postinstall.package.upgrade.sh
8 postgresql.rhel5
8 postgresql
8 ntpdWatchDogd
8 makenetconf.sh
8 ICE_ACS_restore.pl
8 eiab.defaults
8 diskwdog
8 cms2acs.xml.backup
8 acsd
4 xntpd
4 xlat_exclude
4 xfer_system_defaults.pl
4 xfer_phone_info.pl
4 xfer_org_defaults.pl
4 xfer_node_id.pl
4 xfer_moh_config.pl
4 xfer_ldap_config.pl
4 xfer_cookiedomain_config.pl
4 xfer_cluster_config.pl
4 wfunctions.pl
4 wdreg
4 vncfixup.sh
4 vmware_decrufticator
4 vacuum_nightly.sh
4 vacuum_hourly.sh
4 users
4 upgrade_slides.pl
4 undo_acs_muxer_alone.sh
4 uber_restart.sh
4 tzone.pl
4 tpwindrvd
4 tftp
4 system.twmrc
4 subst.pl
4 step-tickers
4 sshd_config
4 snmp.conf
4 showlog
4 settz.sh
4 set_phoneFormattingRules.pl
4 set_das_rules.pl
4 serverstatus.pl
4 sendmailwdogd
4 sendmail.monitor
4 sendmailconf.sh
4 sendevent.pl
4 sendalarm.pl
4 rsyncd.conf.in
4 rsyncd.conf
4 rsync
4 rpm-standalone
4 rpm
4 root.procmailrc
4 restart_2016-11-20-12-30-30
4 restart_2016-11-20-12-28-23
4 restart_2016-11-20-12-26-16
4 restart_2016-11-20-12-24-09
4 restart_2016-11-20-12-22-02
4 restart_2016-11-20-12-19-54
4 restart_2016-11-20-12-17-47
4 restart_2016-11-20-12-15-40
4 restart_2016-11-20-12-13-33
4 restart_2016-11-20-12-11-26
4 restart_2016-11-20-12-09-19
4 restart_2016-11-20-12-07-12
4 restart_2016-11-20-12-05-05
4 restart_2016-11-20-12-02-58
4 restart_2016-11-20-12-00-51
4 restart_2016-11-20-11-58-44
4 restart_2016-11-20-11-56-37
4 restart_2016-11-20-11-54-29
4 restart_2016-11-20-11-52-22
4 restart_2016-11-20-11-50-15
4 restart_2016-11-20-11-48-08
4 restart_2016-11-20-11-46-01
4 restart_2016-02-18-14-46-41
4 restart_2016-02-18-14-44-34
4 restart_2016-02-18-14-42-27
4 restart_2016-02-18-14-40-20
4 restart_2016-02-18-14-38-12
4 restart_2016-02-18-14-36-05
4 restart_2016-02-18-14-33-58
4 restart_2016-02-18-14-23-58
4 restart_2016-02-18-14-21-51
4 restart_2016-02-18-14-19-44
4 resetwebadmin.sh
4 remountVmFs.sh
4 remountVmFs.pl
4 rebuildindices.sh
4 rc.local
4 procmailrc.rootuser
4 postinstall.package.sh
4 postinstall.logcheck.sh
4 postinstall.init.sh
4 postinstall.conf.sh
4 ot_patch_install
4 openser
4 ntpwdogd
4 ntpd.sysconfig
4 ntpd.monitor
4 ntpd
4 ntp.conf
4 nightly-cleanup.sh
4 menu
4 makeroutes.sh
4 logcheck
4 log4perl.conf
4 lib
4 ldap.conf
4 lcheck.pl
4 lcheckd
4 kudzu
4 kamailio
4 issue.net
4 issue
4 isPortUsed.sh
4 iptables.standalone
4 iptables
4 ipchains
4 inittab
4 inetd.conf
4 importsip.pl
4 iceVersion.sh
4 ice-fixrootmail.sh
4 ice-fixrootmail.log
4 ICE_ACS_restore.sh
4 ICE_ACS_initialize_replication.pl
4 ICE_ACS_cleardb.pl
4 ICE_ACS_backup.sh
4 greplog.pl
4 gettag.pl
4 getMac.pl
4 getDomainOutgoingAdminEmail.pl
4 functions.acs
4 forward.rootuser
4 fixservices.sh
4 fixroot.sh
4 fixperms-small.sh
4 fixperms.sh
4 fixcmsxml.sh
4 ensureBackupServer.sh
4 encrypt_on_upgrade
4 eiabtrunkmail
4 eiab.site
4 eiabpackage
4 eiabmail
4 eiabinit
4 eiabet
9852 /usr/sbin/smbd
8488 /usr/bin/net
7320 /usr/bin/mysql
224 dialog
160 dir_protect.so
112 HASPserno
104 pcitable
104 nightly-cleanup
44 eiab.conf
28 cmsxml2conf.pl
24 edialinitial
20 xte
20 set_stacking.pl
16 rc.sysinit
16 mime.types
12 vmfunctions
12 openser.cfg
12 kamailio.cfg
12 functions
12 compresslogs
12 cms2acs.xml
12 acsLcaProxy
8 upgradeconf.sh
8 serverstatus.sh
8 sendmailWatchDogd
8 revertbox.sh
8 process_args.sh
8 postgresql.rhel5
8 postgresql
8 ntpdWatchDogd
8 makenetconf.sh
8 eiab.defaults
8 diskwdog
8 acsd
4 xntpd
4 xlat_exclude
4 xfer_node_id.pl
4 wfunctions.pl
4 wdreg
4 vncfixup.sh
4 vacuum_nightly.sh
4 vacuum_hourly.sh
4 users
4 upgrade_slides.pl
4 uber_restart.sh
4 tzone.pl
4 tpwindrvd
4 tftp
4 system.twmrc
4 subst.pl
4 step-tickers
4 sshd_config
4 snmp.conf
4 showlog
4 settz.sh
4 set_das_rules.pl
4 serverstatus.pl
4 sendmailwdogd
4 sendmail.monitor
4 sendmailconf.sh
4 sendevent.pl
4 sendalarm.pl
4 rsyncd.conf.in
4 rsyncd.conf
4 rsync
4 rpm-standalone
4 rpm
4 root.procmailrc
4 resetwebadmin.sh
4 remountVmFs.sh
4 remountVmFs.pl
4 rebuildindices.sh
4 rc.local
4 ot_patch_install
4 openser
4 ntpwdogd
4 ntpd.sysconfig
4 ntpd.monitor
4 ntpd
4 ntp.conf
4 menu
4 makeroutes.sh
4 logcheck
4 log4perl.conf
4 lib
4 ldap.conf
4 lcheck.pl
4 lcheckd
4 kudzu
4 kamailio
4 issue.net
4 issue
4 isPortUsed.sh
4 iptables
4 ipchains
4 inittab
4 inetd.conf
4 importsip.pl
4 iceVersion.sh
4 ICE_ACS_backup.sh
4 greplog.pl
4 gettag.pl
4 getMac.pl
4 functions.acs
4 forward.rootuser
4 fixservices.sh
4 fixroot.sh
4 fixperms-small.sh
4 fixperms.sh
4 fixcmsxml.sh
4 eiabtrunkmail
4 eiab.site
4 eiabpackage
4 eiabmail
4 eiabinit
4 eiabet
Look into the directory /usr/eiab and you will find all these directories starting with restart_ ... in there. They are created every two minutes.
According to the Technical Knowledge Base, you can delete all those.
This problem is solved with version 2.1.100.052
