recommendation on bulk backups for OS6855
Agentj888
Post by Agentj888 »
I need some recommendation on backing up config for OS6855. I tried below solarwinds recommendation but didnt work. I'm currently using rconfig and having issue. Basically, the problem is > as part of the hostname stops the show configuration snapshot.
https://thwack.solarwinds.com/docs/DOC-174783
Tommy124
Re: recommendation on bulk backups for OS6855
Post by Tommy124 »
librenms and oxidized does the job for me, you could also always buy Omnivista 2500.
Return to “OmniSwitch 6855”
