MWI not working on IPTouch sets connected to OTBE
jeremy13400
Post by jeremy13400 »
I have an OTBE R2.2 with IPTouch sets using local storage voicemail. The voicemails are working fine but the MWI of the sets isn't blinking when they receive new messages (although the message can be listened).
I can't find much intel about this, maybe someone here faced this issue before and could help?
Thank you for reading!
Bye
Split
Re: MWI not working on IPTouch sets connected to OTBE
Post by Split »
On oxe side:
8&9 series > Phone Cos 0 > MWi on Homepage is set default to false >> change to true and it should work
ACSE OmniPCX Enterprise Business R9/10/11
ACSE ICS 8400 R6
ACSE OpenTouch R1/R2
jeremy13400
Hello!
Thank you for your suggestion but I can't find this parameter anywhere in Phone COS. Closest thing I found is "Disp non replied if homepage" and It's already checked.
Any idea?
Maybe because of the language of MGR
Try mgr -l GEA
Split
Post by Split »
Alcatel-lucent 8&9 Serie > 8&9 Serie Cos > Phone Cos 0 > Displ. unans Calls if Homepage app > True
Other idea
Application > external Voicemail for oxe user > Subscription on registration has set to true
ACSE ICS 8400 R6
murraya
Post by murraya »
hi, had a similar issue with OXE phones after upgrade to OT 2.1.1 and it was related to a subscription issue on the OXE. the quick fix was to restart sip motor on OXE but full fix is to upgrade l2.300.25.d to l2.300.26.a.
not sure if it helps but you could try a sipmotor restart.
our case was noted as similar to crqms00189208
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
jeremy13400
Try mgr -l GEA
-> Already tried but no luck
-> Called "Disp non replied if Homepage" in my system and already checked when I first found that non replied calls where not displayed (doesn't solve voicemail issue unfortunately).
Other idea
-> Read this somewhere before posting here and it's also activated on my oxe
-> I'll definitely check this out, I am currently in l1301.29 but there might be a fix available on BPS for R11.1 as well.
Thank you for sharing guys...
EDIT :
l1301.36 :
crqms00198363 4_minor customerSite "No MWI indication in the IP phones while calling from some mobile phones._//1-191161111//"
sipmotor crqms00189208 crqms00195046 crqms00189659 crqms00194881 crqms00199927 crqms00195149 crqms00200152
You are a god, don't know why i didn't check this before...
Return to “OTBE - OpenTouch Business Edition”
