no Timos found
ejamdef
no Timos found
Post by ejamdef »
I deleted all the config files on the cf3:, no my SAR-A 7705 can't find the image. Is there a way to reload new image? I have tried to point to the location
cf3:\7705-TiMOS-7.0.R3 but it still can't fine the image. How can I reload an image with no IP connectivity?
Using: 'cf3:\7705-TiMOS-7.0.R3/'
Auto-Discovery
This system is equipped with TiMOS
Auto-Discovery.
Would you like to enable auto-discovery? (yes/no)
'yes' or 'no' ?
Configuration File Location
You must enter the location of configuration
file to be used by TiMOS. The file can be on
a Compact Flash device, or on the network.
Here are some examples
cf1:/config.cfg
ftp://user:passwd@192.168.1.150/./config.cfg
ftp://user:passwd@[3FFE::1]/./config.cfg
tftp://192.168.1.150/./config.cfg
tftp://[3FFE::1]/./config.cfg
thanks for your assistance
lo0
Re: no Timos found
Post by lo0 »
List CF3's root directory, please.
Stoffen
Re: no Timos found
Post by Stoffen »
I doesnt say it has no image, it says it has no config.
Create an empty file, like config.cfg and point your BOF to that file.
SROS needs a config file, it may be empty, but it must exist..
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
Return to “7705 SAR”
