I try to connect an alcatel OXE and an Asterisk Xivo according to some posts I have seen on this forum but it fail...
Here is the debug call form xivo user to OXE user:
xivo*CLI> sip set debug peer OXE
SIP Debugging Enabled for IP: XXX.XXX.XXX.XXX
[Sep 26 17:12:39] == Manager 'xivo_cti_user' logged on from 127.0.0.1
[Sep 26 17:12:43] == Using SIP RTP CoS mark 5
[Sep 26 17:12:43] -- Executing [2266@default:1] Set("SIP/ifvdbq1h-00000000", "XIVO_BASE_CONTEXT=default") in new stack
[Sep 26 17:12:43] -- Executing [2266@default:2] Set("SIP/ifvdbq1h-00000000", "XIVO_BASE_EXTEN=2266") in new stack
[Sep 26 17:12:43] -- Executing [2266@default:3] Gosub("SIP/ifvdbq1h-00000000", "outcall,s,1(3,)") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:1] Set("SIP/ifvdbq1h-00000000", "XIVO_DSTID=3") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:2] Set("SIP/ifvdbq1h-00000000", "XIVO_PRESUBR_GLOBAL_NAME=OUTCALL") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:3] Set("SIP/ifvdbq1h-00000000", "XIVO_SRCNUM=667") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:4] Set("SIP/ifvdbq1h-00000000", "XIVO_DSTNUM=2266") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:5] Set("SIP/ifvdbq1h-00000000", "XIVO_CONTEXT=default") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:6] Gosub("SIP/ifvdbq1h-00000000", "originate-caller-id,s,1") in new stack
[Sep 26 17:12:43] -- Executing [s@originate-caller-id:1] GotoIf("SIP/ifvdbq1h-00000000", "0?:name") in new stack
[Sep 26 17:12:43] -- Goto (originate-caller-id,s,3)
[Sep 26 17:12:43] -- Executing [s@originate-caller-id:3] GotoIf("SIP/ifvdbq1h-00000000", "0?:fix") in new stack
[Sep 26 17:12:43] -- Goto (originate-caller-id,s,5)
[Sep 26 17:12:43] -- Executing [s@originate-caller-id:5] GotoIf("SIP/ifvdbq1h-00000000", "?:end") in new stack
[Sep 26 17:12:43] -- Goto (originate-caller-id,s,8)
[Sep 26 17:12:43] -- Executing [s@originate-caller-id:8] Return("SIP/ifvdbq1h-00000000", "") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:7] AGI("SIP/ifvdbq1h-00000000", "agi://127.0.0.1/outgoing_user_set_features") in new stack
[Sep 26 17:12:43] agi://127.0.0.1/outgoing_user_set_features: AGI handler 'outgoing_user_set_features' successfully executed
[Sep 26 17:12:43] -- <SIP/ifvdbq1h-00000000>AGI Script agi://127.0.0.1/outgoing_user_set_features completed, returning 0
[Sep 26 17:12:43] -- Executing [s@outcall:8] Gosub("SIP/ifvdbq1h-00000000", "xivo-subroutine,s,1()") in new stack
[Sep 26 17:12:43] -- Executing [s@xivo-subroutine:1] GotoIf("SIP/ifvdbq1h-00000000", "?:nosubroutine") in new stack
[Sep 26 17:12:43] -- Goto (xivo-subroutine,s,4)
[Sep 26 17:12:43] -- Executing [s@xivo-subroutine:4] Return("SIP/ifvdbq1h-00000000", "") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:9] Gosub("SIP/ifvdbq1h-00000000", "xivo-user_rights_check,s,1") in new stack
[Sep 26 17:12:43] -- Executing [s@xivo-user_rights_check:1] AGI("SIP/ifvdbq1h-00000000", "agi://127.0.0.1/user_set_call_rights") in new stack
[Sep 26 17:12:43] agi://127.0.0.1/user_set_call_rights: AGI handler 'user_set_call_rights' successfully executed
[Sep 26 17:12:43] -- <SIP/ifvdbq1h-00000000>AGI Script agi://127.0.0.1/user_set_call_rights completed, returning 0
[Sep 26 17:12:43] -- Executing [s@xivo-user_rights_check:2] GotoIf("SIP/ifvdbq1h-00000000", "ALLOW?:error,1") in new stack
[Sep 26 17:12:43] -- Executing [s@xivo-user_rights_check:3] GotoIf("SIP/ifvdbq1h-00000000", "1?allow,1") in new stack
[Sep 26 17:12:43] -- Goto (xivo-user_rights_check,allow,1)
[Sep 26 17:12:43] -- Executing [allow@xivo-user_rights_check:1] NoOp("SIP/ifvdbq1h-00000000", "User allowed to make call") in new stack
[Sep 26 17:12:43] -- Executing [allow@xivo-user_rights_check:2] Return("SIP/ifvdbq1h-00000000", "") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:10] AGI("SIP/ifvdbq1h-00000000", "agi://127.0.0.1/check_schedule") in new stack
[Sep 26 17:12:43] agi://127.0.0.1/check_schedule: AGI handler 'check_schedule' successfully executed
[Sep 26 17:12:43] -- <SIP/ifvdbq1h-00000000>AGI Script agi://127.0.0.1/check_schedule completed, returning 0
[Sep 26 17:12:43] -- Executing [s@outcall:11] GotoIf("SIP/ifvdbq1h-00000000", "0?CLOSED,1") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:12] GotoIf("SIP/ifvdbq1h-00000000", "?:14") in new stack
[Sep 26 17:12:43] -- Goto (outcall,s,14)
[Sep 26 17:12:43] -- Executing [s@outcall:14] GotoIf("SIP/ifvdbq1h-00000000", "SIP/OXE?:error,1") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:15] Set("SIP/ifvdbq1h-00000000", "TRUNKINDEX=0") in new stack
[Sep 26 17:12:43] -- Executing [s@outcall:16] Goto("SIP/ifvdbq1h-00000000", "dial,1") in new stack
[Sep 26 17:12:43] -- Goto (outcall,dial,1)
[Sep 26 17:12:43] -- Executing [dial@outcall:1] Set("SIP/ifvdbq1h-00000000", "INTERFACE=SIP/OXE") in new stack
[Sep 26 17:12:43] -- Executing [dial@outcall:2] Set("SIP/ifvdbq1h-00000000", "TRUNKEXTEN=2266") in new stack
[Sep 26 17:12:43] -- Executing [dial@outcall:3] Set("SIP/ifvdbq1h-00000000", "TRUNKSUFFIX=") in new stack
[Sep 26 17:12:43] -- Executing [dial@outcall:4] Gosub("SIP/ifvdbq1h-00000000", "xivo-global-subroutine,s,1") in new stack
[Sep 26 17:12:43] -- Executing [s@xivo-global-subroutine:1] GotoIf("SIP/ifvdbq1h-00000000", "1?:return") in new stack
[Sep 26 17:12:43] -- Executing [s@xivo-global-subroutine:2] GotoIf("SIP/ifvdbq1h-00000000", "OUTCALL?:return") in new stack
[Sep 26 17:12:43] -- Executing [s@xivo-global-subroutine:3] GotoIf("SIP/ifvdbq1h-00000000", "xivo-subrgbl-outcall?:return") in new stack
[Sep 26 17:12:43] -- Executing [s@xivo-global-subroutine:4] GotoIf("SIP/ifvdbq1h-00000000", "0?:return") in new stack
[Sep 26 17:12:43] -- Goto (xivo-global-subroutine,s,6)
[Sep 26 17:12:43] -- Executing [s@xivo-global-subroutine:6] Return("SIP/ifvdbq1h-00000000", "") in new stack
[Sep 26 17:12:43] -- Executing [dial@outcall:5] CELGenUserEvent("SIP/ifvdbq1h-00000000", "XIVO_OUTCALL") in new stack
[Sep 26 17:12:43] -- Executing [dial@outcall:6] Set("SIP/ifvdbq1h-00000000", "CONNECTEDLINE(num,i)=2266") in new stack
[Sep 26 17:12:43] -- Executing [dial@outcall:7] Dial("SIP/ifvdbq1h-00000000", "SIP/OXE/2266,,o(2266)") in new stack
[Sep 26 17:12:43] Audio is at 13206
[Sep 26 17:12:43] Adding codec alaw to SDP
[Sep 26 17:12:43] Adding codec ulaw to SDP
[Sep 26 17:12:43] Adding codec g723 to SDP
[Sep 26 17:12:43] Adding non-codec 0x1 (telephone-event) to SDP
[Sep 26 17:12:43] Reliably Transmitting (no NAT) to XXX.XXX.XXX.XXX:5060:
[Sep 26 17:12:43] INVITE sip:2266@XXX.XXX.XXX.XXX:5060 SIP/2.0
[Sep 26 17:12:43] Via: SIP/2.0/UDP XXX.XXX.XXX.XXX:5060;branch=z9hG4bK03aa1085
[Sep 26 17:12:43] Max-Forwards: 70
[Sep 26 17:12:43] From: "jean-marc " <sip:mtcl@XXX.XXX.XXX.XXX>;tag=as20b11e65
[Sep 26 17:12:43] To: <sip:2266@XXX.XXX.XXX.XXX:5060>
[Sep 26 17:12:43] Contact: <sip:mtcl@XXX.XXX.XXX.XXX:5060>
[Sep 26 17:12:43] Call-ID: 17afe02c4d9f68f00087657b14c49dcf@XXX.XXX.XXX.XXX
[Sep 26 17:12:43] CSeq: 102 INVITE
[Sep 26 17:12:43] User-Agent: XIVO PBX
[Sep 26 17:12:43] Date: Mon, 26 Sep 2016 15:12:43 GMT
[Sep 26 17:12:43] Session-Expires: 1860
[Sep 26 17:12:43] Min-SE: 190
[Sep 26 17:12:43] Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
[Sep 26 17:12:43] Supported: replaces, timer
[Sep 26 17:12:43] Remote-Party-ID: "jean-marc " <sip:667@XXX.XXX.XXX.XXX>;party=calling;privacy=off;screen=no
[Sep 26 17:12:43] Content-Type: application/sdp
[Sep 26 17:12:43] Content-Length: 317
[Sep 26 17:12:43]
[Sep 26 17:12:43] v=0
[Sep 26 17:12:43] o=root 987193067 987193067 IN IP4 XXX.XXX.XXX.XXX
[Sep 26 17:12:43] s=Asterisk PBX 13.9.1
[Sep 26 17:12:43] c=IN IP4 XXX.XXX.XXX.XXX
[Sep 26 17:12:43] t=0 0
[Sep 26 17:12:43] m=audio 13206 RTP/AVP 8 0 4 101
[Sep 26 17:12:43] a=rtpmap:8 PCMA/8000
[Sep 26 17:12:43] a=rtpmap:0 PCMU/8000
[Sep 26 17:12:43] a=rtpmap:4 G723/8000
[Sep 26 17:12:43] a=fmtp:4 annexa=no
[Sep 26 17:12:43] a=rtpmap:101 telephone-event/8000
[Sep 26 17:12:43] a=fmtp:101 0-16
[Sep 26 17:12:43] a=ptime:20
[Sep 26 17:12:43] a=maxptime:150
[Sep 26 17:12:43] a=sendrecv
[Sep 26 17:12:43]
[Sep 26 17:12:43] ---
[Sep 26 17:12:43] -- Called SIP/OXE/2266
[Sep 26 17:12:43]
[Sep 26 17:12:43] <--- SIP read from UDP:XXX.XXX.XXX.XXX:5060 --->
[Sep 26 17:12:43] SIP/2.0 100 Trying
[Sep 26 17:12:43] Content-Length: 0
[Sep 26 17:12:43]
[Sep 26 17:12:43]
[Sep 26 17:12:43] <------------->
[Sep 26 17:12:43] --- (7 headers 0 lines) ---
[Sep 26 17:12:44]
[Sep 26 17:12:44] <--- SIP read from UDP:XXX.XXX.XXX.XXX:5060 --->
[Sep 26 17:12:44] SIP/2.0 422 Session Timer Too Small
[Sep 26 17:12:44] Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
[Sep 26 17:12:44] User-Agent: OmniPCX Enterprise R10.0 j1.410.49.a
[Sep 26 17:12:44] Min-SE: 43200
[Sep 26 17:12:44] To: <sip:2266@XXX.XXX.XXX.XXX:5060>;tag=6b7c65ad13af8ac975c452c7e9f5faee
[Sep 26 17:12:44] From: "jean-marc " <sip:mtcl@XXX.XXX.XXX.XXX>;tag=as20b11e65
[Sep 26 17:12:44] Call-ID: 17afe02c4d9f68f00087657b14c49dcf@XXX.XXX.XXX.XXX
[Sep 26 17:12:44] CSeq: 102 INVITE
[Sep 26 17:12:44] Via: SIP/2.0/UDP XXX.XXX.XXX.XXX:5060;branch=z9hG4bK03aa1085
[Sep 26 17:12:44] Content-Length: 0
[Sep 26 17:12:44]
[Sep 26 17:12:44]
[Sep 26 17:12:44] <------------->
[Sep 26 17:12:44] --- (10 headers 0 lines) ---
[Sep 26 17:12:44] Transmitting (no NAT) to XXX.XXX.XXX.XXX:5060:
[Sep 26 17:12:44] ACK sip:2266@XXX.XXX.XXX.XXX:5060 SIP/2.0
[Sep 26 17:12:44] Max-Forwards: 70
[Sep 26 17:12:44] Contact: <sip:mtcl@XXX.XXX.XXX.XXX:5060>
[Sep 26 17:12:44] CSeq: 102 ACK
[Sep 26 17:12:44] User-Agent: XIVO PBX
[Sep 26 17:12:44]
[Sep 26 17:12:44]
[Sep 26 17:12:44] Audio is at 13206
[Sep 26 17:12:44] Adding codec alaw to SDP
[Sep 26 17:12:44] Adding codec ulaw to SDP
[Sep 26 17:12:44] Adding codec g723 to SDP
[Sep 26 17:12:44] Adding non-codec 0x1 (telephone-event) to SDP
[Sep 26 17:12:44] Reliably Transmitting (no NAT) to XXX.XXX.XXX.XXX:5060:
[Sep 26 17:12:44] INVITE sip:2266@XXX.XXX.XXX.XXX:5060 SIP/2.0
[Sep 26 17:12:44] Via: SIP/2.0/UDP XXX.XXX.XXX.XXX:5060;branch=z9hG4bK57c845ae
[Sep 26 17:12:44] CSeq: 103 INVITE
[Sep 26 17:12:44] Date: Mon, 26 Sep 2016 15:12:43 GMT
[Sep 26 17:12:44] Session-Expires: 43200
[Sep 26 17:12:44] Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
[Sep 26 17:12:44] Supported: replaces, timer
[Sep 26 17:12:44] Remote-Party-ID: "jean-marc " <sip:667@XXX.XXX.XXX.XXX>;party=calling;privacy=off;screen=no
[Sep 26 17:12:44] Content-Type: application/sdp
[Sep 26 17:12:44] Content-Length: 317
[Sep 26 17:12:44]
[Sep 26 17:12:44] v=0
[Sep 26 17:12:44] o=root 987193067 987193068 IN IP4 XXX.XXX.XXX.XXX
[Sep 26 17:12:44] s=Asterisk PBX 13.9.1
[Sep 26 17:12:44] c=IN IP4 XXX.XXX.XXX.XXX
[Sep 26 17:12:44] t=0 0
[Sep 26 17:12:44] m=audio 13206 RTP/AVP 8 0 4 101
[Sep 26 17:12:44] a=rtpmap:8 PCMA/8000
[Sep 26 17:12:44] a=rtpmap:0 PCMU/8000
[Sep 26 17:12:44] a=rtpmap:4 G723/8000
[Sep 26 17:12:44] a=fmtp:4 annexa=no
[Sep 26 17:12:44] a=rtpmap:101 telephone-event/8000
[Sep 26 17:12:44] a=fmtp:101 0-16
[Sep 26 17:12:44] a=ptime:20
[Sep 26 17:12:44] a=maxptime:150
[Sep 26 17:12:44] a=sendrecv
[Sep 26 17:12:44]
[Sep 26 17:12:44]
[Sep 26 17:12:44] SIP/2.0 100 Trying
[Sep 26 17:12:44]
[Sep 26 17:12:44]
[Sep 26 17:12:44] --- (7 headers 0 lines) ---
[Sep 26 17:12:44]
[Sep 26 17:12:44] SIP/2.0 404 Not Found
[Sep 26 17:12:44] To: <sip:2266@XXX.XXX.XXX.XXX:5060>;tag=ed76b849a1efcaef37284c303c067d71
[Sep 26 17:12:44]
[Sep 26 17:12:44]
[Sep 26 17:12:44] --- (9 headers 0 lines) ---
[Sep 26 17:12:44] CSeq: 103 ACK
[Sep 26 17:12:44]
[Sep 26 17:12:44]
[Sep 26 17:12:44] Scheduling destruction of SIP dialog '17afe02c4d9f68f00087657b14c49dcf@XXX.XXX.XXX.XXX' in 32000 ms (Method: INVITE)
[Sep 26 17:12:44] == Everyone is busy/congested at this time (1:0/0/1)
[Sep 26 17:12:44] -- Executing [dial@outcall:8] Goto("SIP/ifvdbq1h-00000000", "CHANUNAVAIL,1") in new stack
[Sep 26 17:12:44] -- Goto (outcall,CHANUNAVAIL,1)
[Sep 26 17:12:44] -- Executing [CHANUNAVAIL@outcall:1] Goto("SIP/ifvdbq1h-00000000", "redial,1") in new stack
[Sep 26 17:12:44] -- Goto (outcall,redial,1)
[Sep 26 17:12:44] -- Executing [redial@outcall:1] Set("SIP/ifvdbq1h-00000000", "TRUNKINDEX=1") in new stack
[Sep 26 17:12:44] -- Executing [redial@outcall:2] GotoIf("SIP/ifvdbq1h-00000000", "?dial,1") in new stack
[Sep 26 17:12:44] -- Executing [redial@outcall:3] Playback("SIP/ifvdbq1h-00000000", "congestion-call") in new stack
[Sep 26 17:12:44] > 0x7f5524005df0 -- Probation passed - setting RTP source address to 10.51.55.168:16470
[Sep 26 17:12:44] -- <SIP/ifvdbq1h-00000000> Playing 'congestion-call.slin' (language 'fr_FR')
[Sep 26 17:12:50] -- Executing [redial@outcall:4] Hangup("SIP/ifvdbq1h-00000000", "") in new stack
[Sep 26 17:12:50] == Spawn extension (outcall, redial, 4) exited non-zero on 'SIP/ifvdbq1h-00000000'
[Sep 26 17:12:50] -- SIP/ifvdbq1h-00000000 Internal Gosub(hangup_handlers,userevent,1) start
[Sep 26 17:12:50] -- Executing [userevent@hangup_handlers:1] NoOp("SIP/ifvdbq1h-00000000", "Sending Hangup userevent") in new stack
[Sep 26 17:12:50] -- Executing [userevent@hangup_handlers:2] UserEvent("SIP/ifvdbq1h-00000000", "Hangup,XIVO_USERUUID: 1c4c5c80-1952-43c5-97c7-009f7f1dc7de") in new stack
[Sep 26 17:12:50] -- Executing [userevent@hangup_handlers:3] Return("SIP/ifvdbq1h-00000000", "") in new stack
[Sep 26 17:12:50] -- SIP/ifvdbq1h-00000000 Internal Gosub(hangup_handlers,userevent,1) complete GOSUB_RETVAL=
Is there a way to view debug log from OXE?
Bryan
