Full IP Hybrid Link between nodes
tailtwist_DUP
Post by tailtwist_DUP »
Hi everyone,
I would just like to check or know. What's the heartbeat/keepalive values between OXEs on the same network before we get the "hybrid link goes down" incident?
For OXE itself im aware of the endpoints keep alive and duplication parameters for redundancy. So where do I find these values between intersites?
Andrew LIM
sadim
Re: Full IP Hybrid Link between nodes
Post by sadim »
I think that keep alive timer is configured under X25 parameters (X25/X25 System Parameters), but first you should check the OXE Hybrid link configuration in all the nodes and your ip network.
Return to “Inter-Node Links”
