Using 6860E as NTP server
MicahNguyen
Post by MicahNguyen »
Hi All,
Is it possilble if we using 6860E as NTP server?
What command needs to do to make 6860E as NTP server?
Thanks you all
Re: Using 6860E as NTP server
It works per default. you don't need to activate it at the server. Only at the ntp clients you configure the 6860 as server. you can check at the server with show ntp server client-list.
MicahNguyen
This mean no need any configuration in 6860E (192.168.60.1) right?
So what about other client ntp switches, can I do as below:
ntp server 192.168.60.1
ntp client enable
Is this enough?
Yes, this is enough.
Sometimes it will be better to allow "ntp server unsynchronized"
Disables an NTP client from invoking tests for NTP server synchronization. This allows the NTP client to synchronize with unsynchronized NTP servers in the network.
sputniki
Post by sputniki »
silvio wrote: 06 Sep 2016 03:17 Sometimes it will be better to allow "ntp server unsynchronized"
I'm thankful to your advice with "ntp server unsyncronized" for the OS64xx- and 685x-switches. But in my opinion the OS6860 and OS6900 have RTC and for security reasons wouldn't it be better to don't trust any unsychronized ntp server more than our built-in RTC...? :?
