Hi there,
i need a setup where traffic with destination 192.168.0.0/16 goes to gateway 192.168.1.1.
All other traffic should be redirected to 192.168.1.2.
I have a 9800E.
Can you guys help me out?
Best regards
Dynamic gateway configuration
Re: Dynamic gateway configuration
PBR - policy based routing is the solution.
You will find in the forum and in userguide infos/examples for it (policy action permanent gateway-ip)
bpquintanilha
Hi Silvio,
the problem was that traffic was being looped when coming back from the router. I had to create a port group with all ports but the router port than apply to my condition. Built-in port groups were not elegible as the router were in that group.
I guess that the documentation on this subject should be improved.
I got it sorted out, thanks for your help.
Barrykeery
the panel legend hows Gateway powerup error...gateway configuration error after i write something to the panel. What causes those errors and how do i fix it? Please help. Thanks
Ryan
Ryan
