OS6900 Virtual-chassis VF-LINK problem
pobboy89209
Post by pobboy89209 »
"Virtual-chassis" Configration
But, "Vf-Link" Can Not Connecting
Only. Link status Up, / VF-Link Status Down
AOS Version 7.3.4.450.R01 GA
See Log
Fri Aug 12 13:21:55 : vfcn main error message:
+++ [vfccQsHandleLinkEvents:327] VFCC : gport 18 LINK UP Invalid Speed 0 CANNOT GET
Fri Aug 12 13:21:55 : vcmCmm vfl warning message:
+++ CMM:vcmCMM_process_vfl_member_diag@2360: Non-operational VFL member (chasId 1, vfl 0, port 1019, status 2)
Fri Aug 12 13:21:55 : vfcm main error message:
I can not solve this problem,
Physical GBIC and Cable is changing
The same Log output
-> show interfaces status
Chas/ DETECTED-VALUES CONFIGURED-VALUES
Slot/ Admin Auto Speed Duplex Pause Speed Duplex Pause Link
Port Status Nego (Mbps) (Mbps) Trap EEE
1/1/1 en dis - - - 10000 Full - dis dis
1/1/2 en dis - - - 10000 Full - dis dis
1/1/3 en dis - - - 10000 Full - dis dis
1/1/4 en dis - - - 10000 Full - dis dis
1/1/5 en dis - - - 10000 Full - dis dis
1/1/6 en dis - - - 10000 Full - dis dis
1/1/7 en dis - - - 10000 Full - dis dis
1/1/8 en dis - - - 10000 Full - dis dis
1/1/9 en dis - - - 10000 Full - dis dis
1/1/10 en dis - - - 10000 Full - dis dis
1/1/11 en dis - - - 10000 Full - dis dis
1/1/12 en dis - - - 10000 Full - dis dis
1/1/13 en dis - - - 10000 Full - dis dis
1/1/14 en dis - - - 10000 Full - dis dis
1/1/15 en dis - - - 10000 Full - dis dis
1/1/16 en dis - - - 10000 Full - dis dis
1/1/17 en dis - - - 10000 Full - dis dis
1/1/18 en dis - - - 10000 Full - dis dis
1/1/19 en en 1000 Full - 10000 Full - dis dis
1/1/20 en dis - - - 10000 Full - dis dis
Interface status Up .....
-> show virtual-chassis vf-link member-port
VFLink mode: Auto
Chassis/VFLink ID Chassis/Slot/Port Oper Is Primary
1/0 1/1/19 Down No
Vf-link Status Down .... Why Down ?...
two Device same Status
What do I need to check?...
pobboy89209
Re: OS6900 Virtual-chassis VF-LINK problem
This problem was resolved
10G GBIC problem
10G GBIC 10EA full set is recognized as 1G GBIC
It is properly recognized by other vendors 10G GBIC
silent
Post by silent »
VFL need to use 10G speed.
devnull
Post by devnull »
silent wrote:VFL need to use 10G speed.
or 40G.
So no original "Alcatel" SFP? -> Your fault ;-)
silent
Post by silent »
or 40G.
ha....yes, I'm lost 40G.
pobboy89209
I did not use a dedicated Alcatel GIBC ..
Although China using a supported GBIC,
GBIC that was recognized as 10G SFP + 1G.
Having lived in another test normal 10G GBIC
Return to “OmniSwitch 6900”
