remove time and date
IKTNH
Post by IKTNH »
Hi.
I am new to alcatel os6450 switch cli commands. I would like to know how to turn off/remove the "date and time" in front of "system name" in session prompt when log into the switch using console cable.
ex:
01/01/01 02:20:01SWITCHNAME
How do I remove the date and time in bold
Thanks in advance for any help....
dartzen
Re: remove time and date
Post by dartzen »
you can edit the prompt with the "session prompt default" command. So for example if you only want the switchname displayed you would type: session prompt default "switchname->" The -> is only in there so you have the arrow behind the switchname. The change will only be seen at next login. Don't forget to save your changes with write memory flash-synchro.
IKTNH
Post by IKTNH »
Thank you for the reply. I have entered the "session prompt default "SWITCHNAME->" command many times, but still the time and date appears when I log into the switch via console or ssh. Could I have activated som timestamp feature on the switch?
dartzen
Post by dartzen »
I've looked in the system documentation and aside from the session prompt default there is also a "prompt" command. With that there is an option to activate a timestamp. The command to disable it is simply "no prompt"
Return to “OmniSwitch 6450”
